JapCarForum Cars, Cars, Cars! Car Audio/Video/Electronics/Security Problem with IS200 head unit
19-08-2016, 03:54 AM
Do you get an error code on screen? Top loading units don't really go wrong like the bottom loaders.
19-08-2016, 03:54 AM #21
19-08-2016, 03:55 AM
parthiban Do you get an error code on screen? Top loading units don't really go wrong like the bottom loaders.
I dunno, I think they do, just perhaps not as often and they're easier to fix ?
19-08-2016, 03:55 AM #22
kam05
19-08-2016, 04:02 AM
My top loader packed up (ERR3) whilst under warranty. As mentioned, Lexus replaced my unit as my car was still under warranty at the time.
My car is a late 2000 model- I guess my car was probably one of the first ones that had the top loading units fitted?
kam05
19-08-2016, 04:02 AM #23
19-08-2016, 04:12 AM
steviewevie I dunno, I think they do, just perhaps not as often and they're easier to fix ?
Sorry mate, I was actually asking the OP if he himself got an error code, not if they did in general :tongue_smilie:
Reason being that I had mine replaced when it was still under warranty as I was getting an intermittent ERR1 code come up on mine.
19-08-2016, 04:12 AM #24
19-08-2016, 08:49 AM
Mine is the Black version. The latest incarnation from Lexus. It is free of any errors and only 3 years old.
The Black units are best ones to have.
19-08-2016, 08:49 AM #25
iLLzLex
19-08-2016, 11:45 PM
Going to follow the instructions stevie sent me to dissamble it and see if i can get the jammed cd's out, if not will have to get 2tongues!
iLLzLex
19-08-2016, 11:45 PM #26
iLLzLex
20-08-2016, 12:25 AM
DJ Wozza The only thing you need to check for is the small number by the cassette slot.
13901-13906 etc
So long as these match you will be ok wether you have a Sat-Nav or not.
My OE Head unit went into a Navigator no worries (PCIronmike's IS200), but please be aware eventually the OE Head Unit will pack up.
Mine lasted in Paul's car about 9 months I think, then it packed up. It was fine in my car & his then one day the CD part just died.
It is so annoying...seems like the most common lexus is200 electrics fault :cursing:... i wouldnt mind getting an aftermarket but i like the OEM look...but if i get the aftermarket i would probably get some sort of fancy dvd screen unit
iLLzLex
20-08-2016, 12:25 AM #27
13901-13906 etc
20-08-2016, 01:30 AM
It is a very common problem on the IS200, yes. Having said that, the IS200 has very few faults, and it's an easy one to get around with an aftermarket unit ! But if you still want the total OEM look you still have an option there.
20-08-2016, 01:30 AM #28
kam05
20-08-2016, 01:36 AM
To the OP: Do you have an ipod? If so, then why not buy a GROM ipod kit that allows you to connect your ipod to the OEM headunit.
You'll be able to keep the OEM look.
kam05
20-08-2016, 01:36 AM #29
20-08-2016, 03:26 AM
Quote:So long as these match you will be ok wether you have a Sat-Nav or not.
__________________
Bit harsh. I am 100% sure only a small percentage fail in reality, but owners clubs magnify this issue and make it look like it is certain that they will fail. An after-market HU can also fail, they are at the end of the day only electronic and will always have some failures.
20-08-2016, 03:26 AM #30
__________________
Views 662
30-09-2022, 11:42 AM
Views 1,193
22-05-2022, 12:25 PM
Views 870
29-04-2021, 08:30 AM
Replies 22
Views 2,008
13-05-2020, 06:41 AM
Last Post by iceman
Views 554
19-03-2020, 01:25 AM
Views 786
16-03-2020, 09:00 AM
Last Post by daz@likwidart
Replies 88
Views 19,647
26-01-2020, 06:18 AM
Last Post by iceman
Views 2,424
30-09-2019, 12:19 PM
Last Post by timmurray85
Views 715
28-09-2019, 08:22 AM
