JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Modifications & Tuning Ultra Under bars sizes
11-10-2016, 02:22 PM
bagsi first spare set of the chassis braces.lol.me would paint them yellow to go with my roll bars.:thumbup1:
11-10-2016, 02:22 PM #21
12-10-2016, 12:03 AM
Dean, I could be wrong, but I think the brake stopper will only really help you with brake feel, it won't fix your brakes if there is any problem with them.
12-10-2016, 12:03 AM #22
15-10-2016, 08:56 AM
Sparkystav does this help?
[Image: markeduup.jpg]
Ok just another question about the sizes, if you look at the pic.
The vertical pipe looks longer than 30 mm because it is sticking up a small bit past the horizontal one. If the horizontal pipe was 30mm and the vertical pipe was also 30mm and 30mm long it would be flush top and bottom.
I can get pipe from my work and it has an OD of 33mm will this be ok, I mean is there room for it because it is slightly bigger
15-10-2016, 08:56 AM #23
15-10-2016, 09:15 AM
goos point, didnt notice that!
15-10-2016, 09:15 AM #24
15-10-2016, 09:46 AM
Ok I measured again the vertical tube and the length is 34mm. Moley you are correct mate.
15-10-2016, 09:46 AM #25
15-10-2016, 09:50 AM
also Moley,
from the pic Dimis posted in his thread a little thicker shouldnt be a problem,
[Image: be1t8lzsj1uq69gsv.jpg]
15-10-2016, 09:50 AM #26
also Moley,
15-10-2016, 09:53 AM
they also look like a replacement for a standard part from the mounting points but cant find any info on toyodiy.com
15-10-2016, 09:53 AM #27
15-10-2016, 10:13 AM
Sparkystav they also look like a replacement for a standard part from the mounting points but cant find any info on toyodiy.com
No mate, there no OEM bars, I had a look
15-10-2016, 10:13 AM #28
15-10-2016, 11:18 AM
I'm going away to Norway some time next week so I'll try and do some in the New Year or if I get the chance I'll do them asap :w00t:
15-10-2016, 11:18 AM #29
15-10-2016, 11:38 AM
excellent mate
15-10-2016, 11:38 AM #30
excellent mate
Views 406
01-04-2019, 05:27 AM
Last Post by Bandit
