JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Coil Pack going?
Coil Pack going?
Coil Pack going?
Pages (3): Previous 1 2 3
alamkhan3980
11-12-2016, 10:59 AM
russelllinn Just got back from the garage and this is the code I have got come up, looks like that'll be my prob then, it's been fueling really bad too, used nearly quarter of a tank on 45 miles!!
P0141 O2Sensor Heater Circuit Malfunction (Bank #1 Sensor #2)
Strange thing is though we unplugged the front sensor after resetting the code to try and throw another code up to double check which sensor it was and no code came up, now plugged it all back together and driven home and still no engine light, time will tell but don't wanna use it with it fueling like that!!
OEM part though £198 :blink:
I had the same problem a while ago on my IS300 and the fault was intermittent until it completely failed and the car was using fuel like there was no tomorrow.
I paid approx £180 for the sensor from Lexus Parts Direct. You can get them a cheaper from the US.
[SIZE="1"]Lexus IS300 Navigator
Engine: ITG ProFilter, Joe-Z Intake Pipe, Custom HKS Super Drager Exhaust, TRD Oil & Rad Cap & Grounding Kit
Suspension: BC Racing Coilovers, Hotchkis ARB's, Chassis Braces & WIM Geometry
Wheels: 18" OZ Ultraleggera & Falken ZE912 Tyres
Styling: Seibon Carbon Fibre Bonnet, Figs Bonnet Struts, Sports Grill, Repositioned Horns & SS Dials
ICE: JVC KW-AVX720 HU, Hifonics ZXI 6410 Amp, MB Quart RUA 216 2-Way Components, StealthBoXz with Infinity 12" Sub & Reverse Camera[/SIZE]
alamkhan3980
11-12-2016, 10:59 AM #21
russelllinn
11-12-2016, 11:18 AM
toxo Yeah it will eat fuel with a broken lambda sensor. Best get it replaced before you go through £198 of fuel Big Grin
PS PM me the part number if you've got it and I'll see what price I can get it for. Likely to be 15%-25% cheaper than retail.
:laugh: you're right i'd end spending it on fuwl before long for sure!! Cheers for the heads up with costs I will get the part number tomorrow and PM you :thumbup1:
steviewevie That code is specifically showing that there's a malfunction in the heater circuit of the sensor (it heats it up to make it work properly). So that's more reliably showing that it is indeed the sensor compared to some other codes which involve the sensor (and possibly other things as well).
It's either the sensor, or the wiring to the ECU, or the ECU itself. By far the most likely cause is a failing sensor.
Thanks Steve I think that it will most likely be the sensor as it sounds the same as Alam had below, best be it's gotta be cheaper than an ECU Confusedhock:
alamkhan3980 I had the same problem a while ago on my IS300 and the fault was intermittent until it completely failed and the car was using fuel like there was no tomorrow.
Cheers for that Alam it is the same symptons, was intemittent now just gone!!
russelllinn
11-12-2016, 11:18 AM #22
11-12-2016, 11:24 AM
Loads of stuff comes up if you search for "IS300 O2 sensor" on US eBay.
11-12-2016, 11:24 AM #23
russelllinn
11-12-2016, 11:39 AM
steviewevie Loads of stuff comes up if you search for "IS300 O2 sensor" on US eBay.
Oh yes and not bad prices either, you can get the two front ones for £150inc P&P. Cheers Steve
russelllinn
11-12-2016, 11:39 AM #24
russelllinn
14-12-2016, 01:40 PM
This company will supply the part I need for £100 delivered what do you guys think of the company looks pretty genuine to me?
http://cgi.ebay.com/ebaymotors/ws/eBayIS...MEWAX%3AIT
russelllinn
14-12-2016, 01:40 PM #25
14-12-2016, 11:37 PM
Sounds good from the listing and seems like they have good feedback ?
14-12-2016, 11:37 PM #26
russelllinn
15-12-2016, 02:33 AM
Yeah I thought the same, it is half price and they have a 30 day money back also so worth a shot! cheers Steve
russelllinn
15-12-2016, 02:33 AM #27
russelllinn
15-12-2016, 02:50 PM
Well since the garage fiddled with the sensors and turned the engine light off it hasn't come back on, what do you guys think, should I still change the sensor anyway?
russelllinn
15-12-2016, 02:50 PM #28
15-12-2016, 11:33 PM
I'd be concerned that the problem will end up coming back again, I can't believe the fiddling has fixed the problem permanently.
15-12-2016, 11:33 PM #29
russelllinn
16-12-2016, 04:34 AM
I was thinking along the same lines Steve I couldn't see how fidddling with it would fix it, I think I willl get the part anyway and go from there.
russelllinn
16-12-2016, 04:34 AM #30
 4 Guest(s)
 4 Guest(s)
Views 934
20-04-2017, 07:49 AM
