JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Abs kicking in when brackin at 10mph
John G
10-04-2017, 08:01 AM
How do u know if its slightly out?
[Image: MySig.jpg]
John G
10-04-2017, 08:01 AM #21
[Image: MySig.jpg]
rob
10-04-2017, 08:02 AM
look at it... it will not be sitting flush in the hub.
rob
10-04-2017, 08:02 AM #22
John G
10-04-2017, 08:03 AM
Just got me dad to check steve. Def abs
[Image: MySig.jpg]
John G
10-04-2017, 08:03 AM #23
[Image: MySig.jpg]
John G
10-04-2017, 08:05 AM
Iv taken them both out already. Seemed to only go in one way an sit a certain way. Without soundin funny. Could u be any more specific as to what u found with urs? Was it after lowering?
[Image: MySig.jpg]
John G
10-04-2017, 08:05 AM #24
[Image: MySig.jpg]
10-04-2017, 08:07 AM
How about taking photo's of both sides and then compare yours to your dads sensor John
10-04-2017, 08:07 AM #25
rob
10-04-2017, 08:11 AM
John G Iv taken them both out already. Seemed to only go in one way an sit a certain way. Without soundin funny. Could u be any more specific as to what u found with urs? Was it after lowering?
i replaced the toe control arms and afterwards had exactly the same problem as you describe, i checked for fault codes, nothing. my mate has the toyota tester, again nothing, i took the wheels off and 1 sensor was not fully seated in the mounting hole, but the bolt was fully home.
I cant really describe it any simpler TBH. take the wheels off and check the sensors are fully into the hub, NOT JUST A QUICK GLANCE A REAL PROPER LOOK, even better, remove them, clean any **** from the sensor tip and refit them.
rob
10-04-2017, 08:11 AM #26
John G
10-04-2017, 08:18 AM
Did u take all the grease off them? We gave them a good clean and put them back on as what we thought as proper. Looks like tomos will be a long day. Both my wheels off an my dads to use as an example and lots of trial and error
[Image: MySig.jpg]
John G
10-04-2017, 08:18 AM #27
[Image: MySig.jpg]
10-04-2017, 08:23 AM
Guessing here, but is the sensor torqued correctly ? Could it just be coming loose, or you've done it too tight and it's sitting wrong ?
10-04-2017, 08:23 AM #28
rob
10-04-2017, 08:26 AM
have a look at the online manual - you will see a good diagram of the sensor not installed properly
rob
10-04-2017, 08:26 AM #29
John G
10-04-2017, 12:15 PM
Have u got a link to the online manual page? Im gona take them off tomos. Clean them then put then back in slowly and start of with say 4 turns of the thread and try that then another turn if not. Just sounds like its gonna be alot of trial an error. :-(
[Image: MySig.jpg]
John G
10-04-2017, 12:15 PM #30
[Image: MySig.jpg]
 7 Guest(s)
 7 Guest(s)
