JapCarForum General Discussions The JCF Lounge Any Plumbers in the house??
Pages (3): Previous 1 2 3
Tango
14-04-2017, 10:17 AM
Here's some pics of one that I put in with soldered fittings from under a basin in a groundfloor utility room. I fitted an in-line ball valve to isolate the tap in the winter, but because of the short length of pipe exposed to the outside I've never had a problem with freezing. The tee off the cold feed is buried behind the tiles.
[Image: tapxv.jpg] [Image: photoqf.jpg]
Tango
14-04-2017, 10:17 AM #21
14-04-2017, 10:27 AM
That is pretty much all i would need outside so cant see it having problems freezing.....so do all of those inline taps have valves built in?
14-04-2017, 10:27 AM #22
Tango
14-04-2017, 11:19 PM
The fitting shown in Marsdendean and my pics is an in-line ball valve for the option to isolate the tap from the water supply. It's turned off and on with a screwdriver.
Parts to set up my outside tap:
-1 off 15mm soldered tee
-3 off 15mm soldered elbows
-15mm copper pipe cut to suit (5 off lengths)
-1 off 15mm in-line ball valve with compression fittings for end connection
-1 off outside tap and flange mounting with 15mm compression fitting
and some PTFE tape for the two threaded connections on the tap.
Edited 27-05-2010, 08:56 AM by Tango.
Tango
14-04-2017, 11:19 PM #23
14-04-2017, 11:22 PM
Cheers Mate, will be doing this at somepoint next week:thumbup1:
14-04-2017, 11:22 PM #24
valo
15-04-2017, 11:56 AM
If you wanted you could always go a bit excessive (like me) and have a hot water outside as well.
[Image: d05fbde3.jpg]
[Image: 20c574a6.jpg]
Although I did re-do all the plumbing while I was at it.
Mitsubishi Lancer Evolution X GSR SST FQ-300 (White Pearlescent)
[Image: sm78015.jpg]
valo
15-04-2017, 11:56 AM #25
03-05-2017, 01:50 AM
Thanks for the input guys, done this last weekend, used copper in the end with an inline ball valve, 'T' and a few bends......had to have more pipe outside then i first thought as it would have been awkward to have run the pipe from inside behind the cupboards so just went straight out and round!
03-05-2017, 01:50 AM #26
03-05-2017, 12:11 PM
Nice job mate, where's the pics and the walkthrough? :w00t:
03-05-2017, 12:11 PM #27
03-05-2017, 10:54 PM
oopps, didnt do one:Fish:.....can post a pic up of a tap on the wall if you like:lol:
03-05-2017, 10:54 PM #28
 4 Guest(s)
 4 Guest(s)
Views 152
13-03-2019, 04:12 AM
Last Post by JonPowellDJ
Views 290
10-02-2019, 05:47 AM
Replies 47
Views 1,959
29-01-2019, 02:43 PM
Replies 23
Views 972
19-07-2018, 03:40 AM
Last Post by Carpediem
Views 391
11-07-2018, 03:16 AM
Views 864
01-06-2018, 01:11 AM
Replies 50
Views 2,684
13-01-2018, 09:26 AM
