JapCarForum Cars, Cars, Cars! Project Cars Nissan Almera GTi (N15)
Pages (14): Previous 1 2 3 4 514 Next
03-05-2017, 08:48 AM
So is that darker at the rear Anees ??
Just to clear things up !!
03-05-2017, 08:48 AM #21
Fozzy
03-05-2017, 09:01 AM
Yeah darker at the rear. The % is the amount of light it lets through, the lower the percentage, the darker the tint
2009 JAE Car Pull Runner Up
2010 JAE Car Pull Failure
Fozzy
03-05-2017, 09:01 AM #22
Chri5
03-05-2017, 09:20 AM
Yeah the lower the % the darker it is.
Limo is around 8% but can get 5% iirc
Chri5
03-05-2017, 09:20 AM #23
N15_GTi
03-05-2017, 01:05 PM
Yeh, I have thought about tinting the windows... But there are a few other bits that need to be done first. But I might look at that when I run out of things to do!
Window tints + wind deflectors might be the next stop after my spacers!
The spacers are going to be a pain in the ****, first they need making up, then I need to source longer studs for each hub... Replacing the studs in the hub will be a **** of a job I bet.
But yeh, its all on the list of things to do! Smile
N15_GTi
03-05-2017, 01:05 PM #24
Fozzy
04-05-2017, 12:01 AM
Whats the spec of the spacers? I.e centre bore, pcd, thickness?
Fozzy
04-05-2017, 12:01 AM #25
N15_GTi
04-05-2017, 02:27 AM
PCD = 4x100, CentreBore = 59.1mm, Thickness = 20mm
But on the spacer itself I would ideally need a mounting spiggot to match the internal diameter of my wheels. So the wheel aligns on the spacer properly.
Cheers
Dan
Edited 15-06-2010, 12:07 PM by N15_GTi.
N15_GTi
04-05-2017, 02:27 AM #26
Cheers
Dan
garyskisplym
05-05-2017, 01:10 PM
an i right in thinking the sr20de endine are the same as the engine used in a s14/ s14a (sr20det) without a turbo??
garyskisplym
05-05-2017, 01:10 PM #27
N15_GTi
05-05-2017, 11:17 PM
Sort of... Same block and a few other bits but the SR20DET, the 'T' doesn't just mean they have added a turbo... There are a few differences such as, lower compression pistons, variable cam intake timing, oil squirters, bigger injectors....
And in the 200sx, its mounted longertudinally...
That said, there are a fair few variants that I don't know much about - 'Black Top', 'Red Top' 'Silver Top' etc.... I think they are dependant on year of release, each with a different tweak here or there.
SR20DET is also in the Pulsar GTi-R. One of the popular conversions is dropping the Pulsar lump in, or Pulsar parts onto the standard engine - Like the turbo and manifold etc... As its all interchangeable...
But the SR20DE is a sounds engine, bombproof! Its no RB26 but it still does the job Smile
Edited 17-06-2010, 08:53 AM by N15_GTi.
N15_GTi
05-05-2017, 11:17 PM #28
Mikey
06-05-2017, 12:23 AM
RB :thumbdown: JZ :thumbup:
Mikey
06-05-2017, 12:23 AM #29
N15_GTi
06-05-2017, 12:49 AM
A thumbs down to an RB, that's a first... Smile
Well anyway, both of them are straight 6 Jap engines.... So you can't go wrong :lol:
N15_GTi
06-05-2017, 12:49 AM #30
 4 Guest(s)
 4 Guest(s)
Views 792
24-04-2023, 02:24 PM
Views 999
30-03-2023, 10:38 AM
Views 862
18-03-2023, 01:09 PM
Views 924
09-03-2023, 05:45 AM
Views 804
02-01-2023, 11:48 AM
Views 987
25-11-2022, 01:49 PM
Views 690
02-03-2022, 03:47 PM
Replies 25
Views 2,640
21-07-2021, 11:48 PM
Views 1,223
10-10-2020, 11:18 PM
Last Post by sexttoitami
Replies 102
Views 6,276
10-06-2020, 10:48 AM
