JapCarForum General Discussions The JCF Lounge Custom Dome Badges
Custom Dome Badges
Custom Dome Badges
26-09-2017, 10:48 AM
Jay this is what I'm looking for ........
[Image: 008-1.jpg]
[Image: 007-1.jpg]
[Image: 006-1.jpg]
[Image: 005-1.jpg]
[Image: 004-1.jpg]
for these wheels....
[Image: 037-1.jpg]
[Image: 038-1.jpg]
the outside size is 70mm
the clip size is metal ring 60 mm and with the plastic clip is 64 or 65 mm
26-09-2017, 10:48 AM #21
[Image: 008-1.jpg]
[Image: 007-1.jpg]
[Image: 006-1.jpg]
[Image: 005-1.jpg]
[Image: 004-1.jpg]
[Image: 037-1.jpg]
[Image: 038-1.jpg]
26-09-2017, 10:59 AM
will see what i can do. might be able to get you something like that. just one question. do they clip in place or are they held from behind.
26-09-2017, 10:59 AM #22
26-09-2017, 11:00 AM
They clip in place mate .
26-09-2017, 11:00 AM #23
26-09-2017, 11:03 AM
will look at work and see what i can come up with. are you planning to put center details on them
26-09-2017, 11:03 AM #24
26-09-2017, 11:09 AM
yes Jay, I got Jason to make me up a set of TTE one that he made for the gear knobs.
And they fit nice on my caps
26-09-2017, 11:09 AM #25
26-09-2017, 11:14 AM
what size are they then mate.
26-09-2017, 11:14 AM #26
26-09-2017, 11:23 AM
25mm I've got one fitted already to a centre cap from my 5'th wheel cap which is not corroded
26-09-2017, 11:23 AM #27
26-09-2017, 11:27 AM
Are they metal or plastic mate? Smile
26-09-2017, 11:27 AM #28
26-09-2017, 11:38 AM
Metal , think aluminium but have not tried the magnet test Huh
26-09-2017, 11:38 AM #29
26-09-2017, 12:46 PM
Just had another look at the pic's mate and they look like alloy? Have you got any fine wire wool? If you have give one a light rub down using autosol and the wire wool to see if it removes the lacquer? If it does and you start to see a shine to it, you can rub the lot down, give them a good clean with white spirit and then give a light coat of spray lacquer, if there too bright give them another coat of lacquer as it will tone them down a little with every coat you give them?
If i polish them they will come up pretty shiny, but can give them a go if you want me to mate? you might just have to tone them down a bit with lacquer when you get them back? i'll give them a couple of coats of lacquer anyway so it gives them a bit of protection :thumbup1:
26-09-2017, 12:46 PM #30
 5 Guest(s)
 5 Guest(s)
Views 282
25-07-2020, 10:51 PM
Last Post by Mrs HollowPoint
Views 409
27-06-2019, 06:48 AM
Last Post by reganlives
