JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Brakes & Suspension Anti Roll Bar drop links
Pages (3): Previous 1 2 3
James S
25-12-2017, 01:04 AM
So do I try get the mole gribs on the threaded end of the bolt??
The clamps are easy to get off, its just the drop links that are a pain. Have only tried the back on too so far.
James S
25-12-2017, 01:04 AM #21
25-12-2017, 01:41 AM
Have a look here matey, it shows you where to use the mole grips CLICK ME?
25-12-2017, 01:41 AM #22
25-12-2017, 06:08 AM
cheers bandit thought i done a walk through on how to do them....i done daves every thing went to plan till the 12mm bolts started snapping!!!had to drill them out!!
25-12-2017, 06:08 AM #23
25-12-2017, 06:15 AM
The bolts that held the anti-roll bar bushes on mine all sheared off, Wayne was not amused.
25-12-2017, 06:15 AM #24
25-12-2017, 07:11 AM
Yeh 2 of mine did too, the 1st i drilled out and the 2nd i gave it a good tap with a chisel to remove the nut, came off very easy and replaced it with a Nyloc nut and bolt :thumbup1:
25-12-2017, 07:11 AM #25
James S
26-12-2017, 07:29 AM
Hmm...think that i need to try some better mole grips. Smile
What size bolt do I need, i'll replace them if I can get them off.
James S
26-12-2017, 07:29 AM #26
James S
26-12-2017, 07:33 AM
Had no problem with the nuts holding the Arb to the car, itsjust the dam drop links!
James S
26-12-2017, 07:33 AM #27
James S
13-01-2018, 10:24 AM
Finally got the rear ARB on Smile Going to try get the front one on this weekend.
Also need to cut my old exhaust bolts off. Working on an old car like mine takes ten times longer because of the rust! LOL!
James S
13-01-2018, 10:24 AM #28
Views 1,328
26-03-2017, 01:55 AM
Last Post by edeath
Views 1,187
14-07-2016, 04:42 AM
