JapCarForum General Discussions New Members Newbie with Corolla T-Sport
mplavery
10-02-2018, 04:03 AM
very nice mate, welcome to the club
2nd BEST IN SHOW (JAE 2011)
3rd BEST MODIFIED (JAE 2011)
[/COLOR]
[/COLOR]
mplavery
10-02-2018, 04:03 AM #21
[/COLOR]
[/COLOR]
James S
10-02-2018, 09:51 AM
2tongues I have driven one only the once and was impressed with the little power boost, bit like a tiny turbo.
Is there a way to get the lift to operate a bit earlier?
There is a system for the Vtec Honda engines, that brings the "lift" in earlier. I can imagine its controlled by the Ecu, maybe a Uni chip or piggy back ecu could be used?
James S
10-02-2018, 09:51 AM #22
James S
10-02-2018, 09:52 AM
Very nice car mate, if you want to swap it for an IS200 let me know, looking for a Tsport myself! Smile
And welcome to the club!
James S
10-02-2018, 09:52 AM #23
Phil01
10-02-2018, 11:19 AM
Looks like the mods may have to open up a "T Sport" forum as a few may soon appear on here,
Phil01
10-02-2018, 11:19 AM #24
10-02-2018, 11:53 AM
James S There is a system for the Vtec Honda engines, that brings the "lift" in earlier. I can imagine its controlled by the Ecu, maybe a Uni chip or piggy back ecu could be used?
I wonder where you could get one of them from ??????????Big GriniscoStu:
10-02-2018, 11:53 AM #25
10-02-2018, 11:54 AM
Welcome to the club and by the way you should never buy any car that Anees advises you to :p
10-02-2018, 11:54 AM #26
newdriftking
10-02-2018, 12:39 PM
Moley: I did try to ignore Anees' advice but seen as I work with him it would be rude not to listen to him! :lol:
But he was trying to persuade me to get a Subaru, but don't think the boss would agree!! Blush
Anyways, I'm happy with what I got, its had the major mods done for me, so I can concentrate on other things now...
newdriftking
10-02-2018, 12:39 PM #27
newdriftking
10-02-2018, 01:07 PM
2tongues.
I think it could be possible, but read on....
there is a reason that Toyota put the lift so high. The reason that lift is set at 6k is because it doesn't make more power than the first cam at lower RPM's. If you lowered the 2nd cam engaugement point to 5,500 rpm or lower, instead of getting a more linear power band, or getting more power earlier, you will instead get a big power loss when lift kicks in. The car would bog down.
No one has been able to crack the factory ECU to modify the lift engaugement. The only device that allows you to adjust VVTL-i is the Apexi Power FC. Like mentioned above, lowering the RPM that lift kicks in results in a power loss instead of a gain. A member of NC.org (M-Spec) lowered the lift to 5,500 RPM with the Power FC when he was tuning his car and had dyno proven power loss because of it. Instead of lowering the lift engaugement to try and stay in the power band, he ended up raising the fuel cut off point so he could rev higher.
newdriftking
10-02-2018, 01:07 PM #28
2tongues.
10-02-2018, 01:14 PM
Only reason I said that is because he / me wanted me to get an Evo but my boss would not let me :ohmy:
10-02-2018, 01:14 PM #29
Phil01
10-02-2018, 01:23 PM
its a complicated subject if your not fully aware of the operation of the internal combustion engine and the physics that go with. its all to do with valve lift duration, timing, air/fuel ratio and to get this to operate in harmony and to extract maximum power then exact science has to be adhered to, as newdriftking has pointed out, get one aspect wrong and you can loose power due to things flame quench, where as the spark propagation or flame can actually go out momentarily and loose power, compression being lost out of the inlet or exhaust port low speed air inertia etc etc.
Probably the easiest option would be to fit a 7 speed gearbox to keep that narrow power band in the sweet spot, one reason why Mr T fitted a six speed box into the T sport, and now other manufacture are fitting 8 speed boxes., just to keep them on the boil
Phil01
10-02-2018, 01:23 PM #30
 4 Guest(s)
 4 Guest(s)
Views 161
27-03-2024, 02:19 AM
Views 161
16-02-2024, 09:27 AM
Last Post by Jimbob-T-Lex
Replies 113
Views 2,440
22-01-2024, 08:05 AM
Replies 22
Views 446
04-01-2024, 12:06 AM
Last Post by Jdesousa
Views 397
29-08-2023, 06:49 PM
Replies 18
Views 444
14-08-2023, 10:18 AM
Last Post by TWIN..TURBO..DAN.
Views 302
04-08-2023, 07:03 AM
Replies 31
Views 593
16-03-2023, 10:53 AM
Views 430
06-03-2023, 09:07 AM
Last Post by kevinsgs300
Views 395
08-02-2023, 04:21 PM
Last Post by Is200kid
