JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Std sat nav / enclosure
16-01-2019, 05:47 AM
i cant comment on the part number but the price sounds about right,
yes its just a case of swapping the guts over to make it work i did the same in my Is200 a few years back
you could try calling Lexus Parts Direct you can find them on-line they might be cheaper than you can find on-line failing that give Toxo a shout he might be able to smash that price ?
16-01-2019, 05:47 AM #21
16-01-2019, 06:19 AM
Looks right to me. What Stav has listed as the 'original' one is 1999-2002 and the 'newer' one is 2002+. Your price looks right too.
16-01-2019, 06:19 AM #22
168
16-01-2019, 07:16 AM
what's the difference between the older and newer one mate? 5 inch or 7 inch i assume?
So, that's the right part number for the 7 inch housing and i assume the original top cover fits all ok?
Cheers for this everyone, I don't mean to sound thick!
northernmonkey
16-01-2019, 07:16 AM #23
16-01-2019, 08:30 AM
Yep the newer one is 7"
And yes if just replaces the same bit on the older one and everything still fits to it.
16-01-2019, 08:30 AM #24
16-01-2019, 11:23 PM
So i need to order one from a 2002+ model to get the 7 inch.
*goes hunting for a 2002+ chassis number, as I've only got a 2001. Grrrrr*
northernmonkey
16-01-2019, 11:23 PM #25
16-01-2019, 11:32 PM
Try saying to the dealer that you accept responsibility if it's wrong, they might not be such a pain in the **** then
16-01-2019, 11:32 PM #26
17-01-2019, 01:06 AM
Sparkystav Yep the newer one is 7"
not all the parts are the same you will also need the 7" housings cover as the slope on the sides is a different angle i think both parts will run you just under £100 if memory serves
17-01-2019, 01:06 AM #27
17-01-2019, 01:15 AM
I didn't know that!
17-01-2019, 01:15 AM #28
I didn't know that!
17-01-2019, 01:17 AM
nor did i mate i found out the hard way Sad
17-01-2019, 01:17 AM #29
17-01-2019, 01:20 AM
this is a 7" housing with a 5"cover
[Image: DSCF0176.jpg]
this is the 7" screen with a 7" lid on it
[Image: IMG_0327.jpg]
17-01-2019, 01:20 AM #30
 4 Guest(s)
 4 Guest(s)
