JapCarForum Trade Area Trade Archive Wanted Archive Skyline R32 4 pot Calipers
Pages (3): Previous 1 2 3
09-09-2018, 11:12 AM
Yeah, that'd work and it's the easiest way around the handbrake problem.
09-09-2018, 11:12 AM #21
Fozzy
09-09-2018, 11:52 AM
Mikey, im about to embark on a bit of an adventure into the world of machinery. Im going to start working at my father in laws workshop. i.e milling and turning machines a plenty. I have a couple of spare sw20 front and rear hubs, so if you want something working, i may well be able to do it, will help me in the long run as well. If you could supply calipers and discs, i can get ther brackets made to suit with the parts i have floating around
2009 JAE Car Pull Runner Up
2010 JAE Car Pull Failure
Fozzy
09-09-2018, 11:52 AM #22
BOOSST
09-09-2018, 12:06 PM
Hurricane Mikey, im about to embark on a bit of an adventure into the world of machinery. Im going to start working at my father in laws workshop. i.e milling and turning machines a plenty. I have a couple of spare sw20 front and rear hubs, so if you want something working, i may well be able to do it, will help me in the long run as well. If you could supply calipers and discs, i can get ther brackets made to suit with the parts i have floating around
Sounds like a plan.. and you need to call me you old tart.. I am going to Rab;s in the morning.. :whistling:
BOOSST
09-09-2018, 12:06 PM #23
10-09-2018, 01:38 AM
BOOSST giving it thought, i suppose an ideal solution would be to have Ant's brackets for the rear which means i don't have to worry about the handbrake problem and then have some skyline 4 pots on the front for additional stopping power.. Which would just mean getting custom brackets made up for the front...
....or, have i missed something lol
That might be the ideal solution for you, and a good compromise on cost and complexity, but with the upgrade in stopping power and disks filling the wheels better.
This setup may well throw off the brake balance (between front and rear) but this can be corrected with the right valve plumbed into the right place, and shouldn't cause much drama.
10-09-2018, 01:38 AM #24
 4 Guest(s)
 4 Guest(s)
Views 579
18-06-2019, 09:08 AM
Views 176
16-04-2018, 04:24 AM
