JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications Supercharger fitting help
Lexuslee
09-10-2019, 12:41 PM
Going into limp mode when I go full throttle
Lexuslee
09-10-2019, 12:41 PM #21
09-10-2019, 12:53 PM
ok
was it doing it before the FCD was fitted i know u saying it was doing it before you got all the charger running etc but just to confirm if the wiring is correct in the ecu....
09-10-2019, 12:53 PM #22
ok
Lexuslee
09-10-2019, 01:07 PM
Yes it was doing it before the fcd was fitted. When I first mounted the Supercharger on the cradle I hooked up the bypass to stop it from falling down, this is when it first happened so I disconnected it and no fault.
Lexuslee
09-10-2019, 01:07 PM #23
09-10-2019, 01:19 PM
have you tied reseting the ecu ?
09-10-2019, 01:19 PM #24
09-10-2019, 01:21 PM
what is the current state of the supercharger? ie connected, spinning, what?
it you have the belt off, fcd off, and the bypass valve attached to the throttle then its starving the engine.
If you have the belt on, bypass on, but no FCD your overloading the engine.
09-10-2019, 01:21 PM #25
Lexuslee
09-10-2019, 01:25 PM
At the mo I got supercharger spinning, fcd connected set to 8 and bypass cable off, no probs but no increase in power, but with bypass on I get more power but cuts out at hard throttle
Lexuslee
09-10-2019, 01:25 PM #26
Lexuslee
Tried resetting
Lexuslee
09-10-2019, 01:25 PM #27
Tried resetting
Lexuslee
09-10-2019, 01:35 PM
I'll try it again on nine and reset for 15 and see I this works. Should I fit the bov?
Lexuslee
09-10-2019, 01:35 PM #28
P.Lindblom
09-10-2019, 01:41 PM
My car behaved the same way when I fitted my supercharger for the first time. It turned out the bypass valve closed too early and the reason was that I fitted this little thingie (component marked in red) on top of the metal plate with the two screws rather than under it. After relocating it I never went into limp mode again.
[Image: dsc1170v.jpg]
Also, are you sure the FCD is connected the right way?
P.Lindblom
09-10-2019, 01:41 PM #29
Lexuslee
09-10-2019, 01:45 PM
I have it on top, maybe that's the problem. Will try it and report back, cheers
Lexuslee
09-10-2019, 01:45 PM #30
Views 2,091
28-05-2024, 10:57 PM
Last Post by Mikedaddy
Views 926
22-05-2024, 06:15 AM
Last Post by ashj25839
Views 566
05-04-2024, 07:48 AM
Replies 24
Views 1,466
12-01-2024, 05:42 PM
Views 239
03-01-2024, 07:08 PM
Views 164
28-12-2023, 04:46 AM
Views 510
02-12-2023, 07:46 PM
Views 528
04-11-2023, 11:43 AM
Views 107
30-07-2023, 07:38 PM
