JapCarForum Cars, Cars, Cars! Project Cars koka and his projekt
08-01-2017, 12:05 PM
#31
thats really not safe if the readings accurate
08-01-2017, 12:05 PM #31
08-01-2017, 12:06 PM
#32
Surely that reading is inaccurate ? At least, I hope so ! :ohmy:
08-01-2017, 12:06 PM #32
08-01-2017, 12:08 PM
#33
He must fit a better aftermarket ecu
08-01-2017, 12:08 PM #33
08-01-2017, 12:27 PM
#34
Sort of, his is based on the TTE SC with some of his own mods/improvements
08-01-2017, 12:27 PM #34
rob
08-01-2017, 01:10 PM
#35
so if he has a 150mm pulley and larger injectors i would expect to see a bit more power!
rob
08-01-2017, 01:10 PM #35
08-01-2017, 01:12 PM
#36
rob so if he has a 150mm pulley and larger injectors i would expect to see a bit more power!
Yeah but did you see his post about the belt slipping at 4500rpm ? Apologies if you had already taken that into consideration though.
08-01-2017, 01:12 PM #36
08-01-2017, 01:14 PM
#37
i reckon he will get a lot more once he gets a tighter belt!
08-01-2017, 01:14 PM #37
Spoon
08-01-2017, 01:16 PM
#38
I had 217 HP with the original TTE setup. Only modified exhaust system.
koka already given up yet!
Respect for this workWink
IS 200 S/C
[Image: 400_6132336436313130.jpg]
Spoon
08-01-2017, 01:16 PM #38
IS 200 S/C
08-01-2017, 01:18 PM
#39
Koka and you Spoon have one of the best modified IS200 SC
08-01-2017, 01:18 PM #39
08-01-2017, 01:19 PM
#40
217 hp thats good for the charger alone
08-01-2017, 01:19 PM #40
