Bonnet Strutts
Bonnet Strutts
I think you are right, however, the bracket is too long and does not allow much clearance for the strutt. You cannot move it nearer to the body as well since;
1. the bracket is already touching the wing
2. the wiring loom is in the way
So, I turned it upside down with the attachment upwards. drilled another hole to move it outwards and placed it between the wing and the body unless you want to cut the bracket
