JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza the car is back
the car is back
the car is back
02-09-2017, 08:17 AM
#31
i'm running 315cc injectors out of the 1g gte engine i brought. had to make a few adjustments to the head with a dremil but was a great fit with only the smallest amount to trip away. good news is now i can run larger ones that are not for my car so it gives me more options when i'm going to upgrade next year
02-09-2017, 08:17 AM #31
LEX11S
03-09-2017, 04:23 AM
#32
thats cool i like that :thumbup1:
LEX11S
03-09-2017, 04:23 AM #32
10-09-2017, 10:27 AM
#33
jay_russell well i tried that sort of thing and as i was getting 236 from standard injectors (150cc) then with my set up i might push the 400 bhp with 315cc that i have now
Standard IS200 injectors are 210cc, as far as I'm aware.
10-09-2017, 10:27 AM #33
10-09-2017, 10:37 AM
#34
nope 155 mate.
http://www.lextreme.com/Injector%20data.htm
10-09-2017, 12:12 PM
#35
jay_russell nope 155 mate.
ok, that doesn't make sense though compared to the IS200 technical manual, unless I'm misunderstanding something.
Take a look at http://bahamutcars.free.fr/workshop/IS_9...i_0023.pdf , specifically point 1(n).
This is the section on checking the correct operation of the injectors. The range of tolerance they give there is between 47 and 58 cm3 in 15 seconds. If you multiply that by four to give the rate per minute, that is between 188 and 232 cm3 per minute. So they surely can't be 155 injectors ? 210 is exactly half way between 188 and 232.
10-09-2017, 12:12 PM #35
10-09-2017, 12:16 PM
#36
I just noticed that in the same section on that table from lextreme.com, they have an entry for another sky blue coloured injector of 213 cc. That sounds more like it, I wonder if they have the 1G-FE and 3F-E labels for sky blue injectors the wrong way round ?
10-09-2017, 12:16 PM #36
10-09-2017, 12:18 PM
#37
I really wish we had an edit button again !
Anyway, I also noticed it says the sky blue injectors have 1 or 2 holes. The IS200 1G-FE injector has 4 holes.
10-09-2017, 12:18 PM #37
10-09-2017, 07:57 PM
#38
Sparkystav lol i'm trying to find a link where basically a guy strapped a massive turbo to the engine and was running 700bhp!
Found it at last!!
http://autospeed.com/cms/A_108678/article.html
10-09-2017, 07:57 PM #38
Found it at last!!
10-09-2017, 09:47 PM
#39
steviewevie Standard IS200 injectors are 210cc, as far as I'm aware.
Stevie standard IS200 injectors are 155cc not 210cc, have a look here:
http://shed51.com/injectors.htm
10-09-2017, 09:47 PM #39
10-09-2017, 09:51 PM
#40
1GFE uses Denso injectors which are violet
10-09-2017, 09:51 PM #40
Views 344
20-03-2019, 09:50 AM
Replies 25
Views 1,589
27-01-2018, 10:18 AM
Last Post by jimxms
Replies 61
Views 3,493
17-01-2018, 04:49 AM
Last Post by jimxms
Views 872
26-12-2017, 11:11 AM
Views 546
23-09-2017, 05:01 AM
Last Post by Phil01
Views 584
28-06-2017, 12:20 PM
Last Post by Fry-Up
Views 810
01-03-2017, 10:30 PM
Views 621
07-06-2016, 07:01 AM
Last Post by Saraj
Views 262
31-05-2016, 08:05 AM
Last Post by Saraj
