JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications supercharger pulley
supercharger pulley
supercharger pulley
buzzard2011
26-11-2018, 01:04 PM
#31
yeah will do dimis thanks for the support.,but ill be buggered if i take the cradle out for some pics,ill leave it in.
just sealed up the intake and outlet on the charger,will fit in the morn and see what sound it makes,hope the bearings ain't shagged or i shall cry......
i think the next prob will be setting the spring on the bov,as im not running a bypass.so that it kicks in at around 3000rpm..that should do it me thinks.
got to do the boost guage as well....will it never end.lol
buzzard2011
26-11-2018, 01:04 PM #31
27-11-2018, 02:18 PM
#32
sounds like youve made progress mate,
i'd suggest getting a SSQV over a normal BOV mate, works off inlet pressure rather than spring pressure, better for what you want
27-11-2018, 02:18 PM #32
buzzard2011
27-11-2018, 03:17 PM
#33
yeah,was looking into a ssqv,then bought a greddy rz cheap should be ok,, maybe,.
got the charger running today,sounds sweet.,an load nearly sucked my hand in through the intake thoughConfusedcared:,jeez them bloers have a lot of suction lmao.
still getting vibrations though,i think ill try a heavier craddle next week if i got time.tried posting pics but got bored trying........:mad:
buzzard2011
27-11-2018, 03:17 PM #33
Talisker
21-12-2018, 04:45 AM
#34
Have you got a part number of the 138mm pulley you've currently got for your system?
I'm interested in getting my grubby mitts on one for my own setup.
Talisker
21-12-2018, 04:45 AM #34
buzzard2011
22-12-2018, 01:28 AM
#35
hope this helps.
Partnumber: G15-22-21
Producer & Producer partnumber:
MERCEDES BENZ: 6032050110
Mercedes analogy numbers:
6032050110, A6032050110
youll need to redrill it though not a problem.:w00t:
buzzard2011
22-12-2018, 01:28 AM #35
hope this helps.
Talisker
22-12-2018, 01:55 AM
#36
Thanks buzzard, just what i needed :w00t:
Talisker
22-12-2018, 01:55 AM #36
S
22-12-2018, 10:07 AM
#37
Stoney try this for a new bypass spring (if you havnt got a replacement already):
http://www.ebay.co.uk/itm/150PC-SPRING-A...35b8c5fe71
S
22-12-2018, 10:07 AM #37
31-05-2019, 12:08 PM
#38
Sorry to drag up an old thread, but I'm hoping a couple of you guys who are subscribed to it can answer my questions Smile
1. Has anyone run the 138mm pulley for a while and can confirm that it works and is safe?
2. Will it line up with the supercharger okay if I'm using an original TTE cradle?
3. Does anyone know the PCD of the holes on the IS200 water pump that need drilling into the 138mm pulley?
31-05-2019, 12:08 PM #38
31-05-2019, 12:39 PM
#39
Could you not take off the little pully cover to get the pcd?
A few people in Europe have run the bigger pulley and yes it lines up.
31-05-2019, 12:39 PM #39
31-05-2019, 01:00 PM
#40
Sparkystav Could you not take off the little pully cover to get the pcd?
I'd need to get the bolts out to get an accurate measurement though wouldn't I? And I don't want to do that until I actually come to fitting it.
And is it that exact pulley (the mercedes one posted above) that they used?
31-05-2019, 01:00 PM #40
Views 1,677
29-05-2023, 05:08 PM
Last Post by Mikedaddy
Views 715
23-05-2023, 12:26 AM
Last Post by ashj25839
Views 468
06-04-2023, 02:00 AM
Replies 24
Views 931
12-01-2023, 11:53 AM
Views 110
03-01-2023, 01:19 PM
Views 85
27-12-2022, 10:58 PM
Views 410
02-12-2022, 01:57 PM
Views 424
04-11-2022, 05:54 AM
Views 58
30-07-2022, 01:49 PM
