My new toys
My new toys
Pages (177): Previous 147 48 49 50 51177 Next
12-02-2018, 04:12 PM
steviewevie That should suit you fine Dimis. And it's fine for cars that spend their life on a racetrack. But guys in the UK - I'd be a bit careful about oil coolers like that. When the weather gets cold (not so much of a problem for Dimis !), your oil will take a lot longer to warm up, therefore the engine won't be working quite so efficiently and the oil may not be doing as good a job as usual (depending on the quality/viscosity of your oil).
You can get an "oilstat", basically a thermostat, which ensures that the oil only goes to the cooler when it gets to a certain temperature, but the sort of setup you find on eBay usually doesn't have one.
Would you run your engine without a thermostat ? It would take a long time for the coolant to warm up if you did.
I am thinking to fit also a thermostat, but if i do not fit one i do not think i will have a major problem. The weather in Greece is not very cold. This year the lowest temperature in Athens was 11C and today the temperature was 20C and shinny. I bought the oil cooler basically for the summer time. The temperatures in summer reach around 40C. Usually in June the temp is around 34 and in August 35-40C and the weather starts to get cold at end of October!
12-02-2018, 04:12 PM #481
russelllinn
12-02-2018, 05:00 PM
O for weather like yours, I think it will suit your needs then Dimis and you will be able to hit the bends fast and not worry so much about the heat :thumbup1:
russelllinn
12-02-2018, 05:00 PM #482
12-02-2018, 05:08 PM
russelllinn O for weather like yours, I think it will suit your needs then Dimis and you will be able to hit the bends fast and not worry so much about the heat :thumbup1:
Yes I believe so :lol:
12-02-2018, 05:08 PM #483
12-02-2018, 07:01 PM
I just found out that the Mocal Oil Cooler Sandwich plate has a built in thermostat, so i do not need to get one! :thumbup:
Edited 26-03-2010, 10:53 PM by dimis.
12-02-2018, 07:01 PM #484
12-02-2018, 07:06 PM
Was just about to say that as i have the same one, (different sized cooler though).
It has a mechanical thermostat already built in at the side of the adaptor
12-02-2018, 07:06 PM #485
12-02-2018, 07:07 PM
Sparkystav Was just about to say that as i have the same one, (different sized cooler though).
Thanks for the information mate. :thumbup:
12-02-2018, 07:07 PM #486
13-02-2018, 05:12 AM
Some of Mocal's sandwich plates come with thermostats, and some don't. They cost a fair bit more with thermostats built in.
As I said before though, for Greece it's really not going to make any difference whether you have one or not though ! :biggrin:
13-02-2018, 05:12 AM #487
13-02-2018, 06:16 AM
Gord Nice mate :biggrin: bit of a pig to fit :thumbdown:
Gord do you remember how much more oil i will need to add in the engine now? 1lt or more?
13-02-2018, 06:16 AM #488
13-02-2018, 12:36 PM
That sort of size of oil cooler is only going to hold about 0.2 litres of oil. So I doubt you'll need to add very much, if any.
13-02-2018, 12:36 PM #489
13-02-2018, 01:00 PM
Would it be worth running the car for a minuet to allow the oil to run around the system, then check.
13-02-2018, 01:00 PM #490
 4 Guest(s)
 4 Guest(s)
