JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Rust !
Rust !
Rust !
Jambo
02-06-2017, 04:05 PM
#41
If its coming from inside. Im guessing if you can then see it, a small poke would make a hole. (If you get me).
If you poke it, and it doesnt feel week, then there may not be any rust "on the inside", just the rust starting on the outside...
Im probably very very wrong though...
Latest Meets
Ace Cafe 16/10/10,
Jambo
02-06-2017, 04:05 PM #41
Latest Meets
Ace Cafe 16/10/10,
rob
04-06-2017, 05:51 AM
#42
have they actually had a good look at it??? as above how do they know its not from the inside? i am guessing as they see surface rust they say thats it not from inside....
i reckon you will end up having the screen out and getting it fixed yourself......
rob
04-06-2017, 05:51 AM #42
04-06-2017, 06:45 AM
#43
rob have they actually had a good look at it??? as above how do they know its not from the inside? i am guessing as they see surface rust they say thats it not from inside....
The bodyshop guy had a pretty good look at it, though I don't know exactly what he wrote in his report.
I do tend to agree with you about what is likely to end up happening though Sad
04-06-2017, 06:45 AM #43
17-06-2017, 10:43 AM
#44
I've written to Lexus GB Customer Relations about this, saying that I believe the fault to be from the original manufacture of the car, to try and give another angle on why the anti-corrosion warranty should cover it.
17-06-2017, 10:43 AM #44
Saraj
17-06-2017, 10:53 AM
#45
hopefully you have better luck with them, good luck !
Saraj
17-06-2017, 10:53 AM #45
kam05
14-07-2017, 12:24 PM
#46
Any updates to report on this Stevie? I'm interested to know the outcome of this.
kam05
14-07-2017, 12:24 PM #46
Tango
14-07-2017, 01:12 PM
#47
Perforation warranty means exactly what it says, i.e. a hole through the panel. Corrosion just showing under the paint isn't covered by the 12 year warranty.
Tango
14-07-2017, 01:12 PM #47
RT
14-07-2017, 01:18 PM
#48
Tango Perforation warranty means exactly what it says, i.e. a hole through the panel. Corrosion just showing under the paint isn't covered by the 12 year warranty.
Well said that man :thumbup1:
RT
14-07-2017, 01:18 PM #48
14-07-2017, 04:33 PM
#49
They sent me a very polite and nicely-worded letter saying "no", basically.
I don't think the point about perforation is quite so clear-cut in this case. Normally rust on the surface is going to be something caused by an imperfection under the paint which shows relatively quickly, or from a stone chip or similar. However my rust, whilst not coming (presumably ? though how do they know ?) from the undernearth of the panel, but seems to be coming from underneath the windscreen sealing itself, and isn't mere surface rust.
14-07-2017, 04:33 PM #49
Tango
14-07-2017, 06:03 PM
#50
You just need to get it fixed, though it will mean removing the screen to do so. I've had the same on a Volvo 480 Turbo, a Lancia and a couple of Vauxhalls. It'll be corrosion from moisture getting in at the edges behind the seal.
Once it's under the paint will carry on spreading, and will just look worse than it is at the mo. Suggest you fix it before it really is a perforation issue, although it'll take longer than what's left of the perforation warranty to do that.
Tango
14-07-2017, 06:03 PM #50
Views 854
21-11-2019, 07:14 AM
Views 1,683
25-01-2018, 05:13 PM
Last Post by spikes
