JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Modifications & Tuning Bonnet Strutts
Bonnet Strutts
Bonnet Strutts
icemahn
28-05-2017, 10:02 PM
#41
the balls are welded to the bracket. I think in the originals strutts, the top bracket(hood part) is longer than this one which gives it more allowance. Can somebody post a pic of the top bracket of the original one(IS IT PPROLEX)?
Mazda CX7. 2.3 Turbo MPS. Corksport air intake. Turbo Smart dual port.
icemahn
28-05-2017, 10:02 PM #41
29-05-2017, 05:03 AM
#42
[Image: e58cbba7.jpg]
here are the brackets from the kit
29-05-2017, 05:03 AM #42
08-06-2017, 11:02 AM
#43
did any one else get these fitted
08-06-2017, 11:02 AM #43
posty
08-06-2017, 11:47 AM
#44
I did! Was pretty simple in the end but a little modification was needed. I had to cut down the bracket on the drivers side wing so it would miss the ABS bolt.
Other than that they work perfectly! :thumbup:
posty
08-06-2017, 11:47 AM #44
08-06-2017, 11:53 AM
#45
got any pics of the cut down
i sent a email to the seller as the item not as described lol.
did you fit the bracket on top of the wing or under...
08-06-2017, 11:53 AM #45
08-06-2017, 04:00 PM
#46
Maybe it fits well on non UK IS cars where the ABS is located at front near the right headlight.
08-06-2017, 04:00 PM #46
posty
12-06-2017, 11:05 AM
#47
Rabster got any pics of the cut down
here you go...
[Image: picture080.jpg]
I drilled the hole in the wrong place the first time :mad: I also need to sort out the rust on that, Only noticed that when I took a photo for you, so cheers!
posty
12-06-2017, 11:05 AM #47
here you go...
12-06-2017, 12:37 PM
#48
Cheers posty
I'll do mine 2moz but gonna put them under the wing I think with the ball joint up
12-06-2017, 12:37 PM #48
Cheers posty
posty
12-06-2017, 12:40 PM
#49
no worries, would you be able to post a pic so I can see what it looks like?
posty
12-06-2017, 12:40 PM #49
15-06-2017, 12:14 PM
#50
OK sorry for the delay here are the pics we couldnt do it balls up as the brackets sat to close to the bonnet and marked it :Chair:
[Image: 187fa7ce.jpg][Image: 9f96d3d1.jpg][Image: 77bdb410.jpg][Image: 074b1c26.jpg][Image: 3a8ee1ef.jpg]
15-06-2017, 12:14 PM #50
Views 1,180
14-08-2019, 11:56 AM
Last Post by is300_dino
Views 945
24-06-2016, 11:02 AM
Last Post by Asi
