JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications TTE Supercharger Install Help!
164
09-07-2018, 08:01 AM
#41
so its just one wire on the ecu i cut, an connect to both cut ends? which wire will it be 1 that i spliced into or a diffrent one?
lookatmybiceps
09-07-2018, 08:01 AM #41
164
09-07-2018, 08:04 AM
#42
i think i get it they both need to be on the 1st blue with yellow wire in series il go and have a look now and get some pics.
lookatmybiceps
09-07-2018, 08:04 AM #42
09-07-2018, 08:05 AM
#43
yeah one cut wire and the new box goes one to the ecu side one to the loom side
i dont know what colour it is but on aj's pic it looks like red and black
09-07-2018, 08:05 AM #43
09-07-2018, 08:24 AM
#44
ok i checked ajs pic and it seems the cut wire was the blue with yellow stripe, it has black tape on it and, the red and yellow wire you left goes to the same place so when i think the blueyellow wire was cut the red and yellow soldered close to the ecu a bit of dead blueyellow wire then the cut side soldered to the brow so i have dont it like this, will go for a drive and test it.[Image: 297755_10150763818255500_574495499_20248...7712_n.jpg]
lookatmybiceps
09-07-2018, 08:24 AM #44
09-07-2018, 08:29 AM
#45
that looks better
09-07-2018, 08:29 AM #45
that looks better
09-07-2018, 08:43 AM
#46
ok still fuel cut so you think its red and black where you put the redyellow wire?
lookatmybiceps
09-07-2018, 08:43 AM #46
09-07-2018, 08:52 AM
#47
thats what it looks like in ajs pic i think
09-07-2018, 08:52 AM #47
09-07-2018, 08:53 AM
#48
[Image: FCDwirings.jpg]
09-07-2018, 08:53 AM #48
09-07-2018, 09:10 AM
#49
ok i tried that but still hits it at 5k rpm im kinda stuck now dont wana keep cuting wires
lookatmybiceps
09-07-2018, 09:10 AM #49
09-07-2018, 02:16 PM
#50
Odd i thought the wire you cut was this:
MAP E5 9 Green Red
Ground ECU B E5 17 Brown
Ignition Power E2 16 Black Red
Edited 21-08-2011, 12:00 AM by Sparkystav.
09-07-2018, 02:16 PM #50
MAP E5 9 Green Red
 4 Guest(s)
 4 Guest(s)
Views 1,677
29-05-2023, 05:08 PM
Last Post by Mikedaddy
Views 710
23-05-2023, 12:26 AM
Last Post by ashj25839
Views 468
06-04-2023, 02:00 AM
Replies 24
Views 931
12-01-2023, 11:53 AM
Views 110
03-01-2023, 01:19 PM
Views 85
27-12-2022, 10:58 PM
Views 410
02-12-2022, 01:57 PM
Views 424
04-11-2022, 05:54 AM
Views 58
30-07-2022, 01:49 PM
