JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Help help help.............
Pages (8): Previous 14 5 6 7 8 Next
22-12-2016, 03:01 AM
#51
rob using the OBD it shows the inlet air temp as 70C using the standard TTE airbox
At what temperature outside ?
22-12-2016, 03:01 AM #51
rob
22-12-2016, 05:22 AM
#52
was about 20c
rob
22-12-2016, 05:22 AM #52
was about 20c
22-12-2016, 05:23 AM
#53
rob was about 20c
So it sounds like the inlet air temp was about the same as the ambient air ?
22-12-2016, 05:23 AM #53
rob was about 20c
22-12-2016, 10:43 AM
#54
my sensor was sitting on the/beside the rocker cover so it would be warmer
22-12-2016, 10:43 AM #54
edeath
23-12-2016, 10:06 AM
#55
yeah ive always been surprised at the temps i get off my air sensor in the air box which can rise to about 70c if in traffic. Anyone gots real (after intercooler) intake temps for the TTE setup? Interested in the difference.
edeath
23-12-2016, 10:06 AM #55
23-12-2016, 10:35 AM
#56
i have mounted my sensor after the intercooler (first silicone pipe after the throttle body)i'll do it tomorrow on the way home,my cars still at my work or i'd do it now..
23-12-2016, 10:35 AM #56
rob
24-12-2016, 12:41 AM
#57
in my mind thats where the temp sensor should be as the air is hotter than ambient. Only concern i have is the sensor could be a pressure leak area as its a push in design.
On the corolla where is the temp sensor and how is it fitted? maybe a swap is possible?
rob
24-12-2016, 12:41 AM #57
28-12-2016, 09:20 AM
#58
dimis That is weird. I can find easily 5PK800 and 5PK790 in Greece. Regarding the noise i agree with Patrick. I think the noise comes from your bearings probably. Better to do the check Patrick suggests.
So what is the best size of belt to fit for the charger, and dose anyone have a link to a good place to get one from, just going to check my belt size because I think its 805 which sounds to big compared to the two that you have mentioned
28-12-2016, 09:20 AM #58
28-12-2016, 09:29 AM
#59
The original belt is the 5pk800, but if you can get the 5pk790 its a better tighter fit so reduces the chance of slipping? Camskill usually stock the 5pk800 but not seen anywhere with the 5pk790 for a while? :thumbup1: CLICKY ME? They have no 5pk790 in stock? i tried the 780 and its too tight but not sure about the 5pk788?
28-12-2016, 09:29 AM #59
28-12-2016, 10:08 AM
#60
5pk788 will NOT fit peeps i try'd for over an hour!!!!
28-12-2016, 10:08 AM #60
