JapCarForum Cars, Cars, Cars! General Car Maintenance 2012 MOT regulations.
Pages (6): Previous 1 2 3 4 5 6
22-08-2018, 09:58 AM
#51
toxo Where has anyone said that is the plan?
Correct all the new regs say is "If your car is modified you better make darn well sure its safely done - or its off the road"
22-08-2018, 09:58 AM #51
22-08-2018, 10:01 AM
#52
I meant more if this does evolve into a crack down on modified cars. I don't see the problem with rigorous tests on modified cars, it does **** me off that you will need a cat even if your car passes emissions though. I just hope it's not a leg up for something a bit more invasive.
22-08-2018, 10:01 AM #52
22-08-2018, 10:03 AM
#53
Nowhere... But the changes noted above do look like they will hinder casual modifiers, John. If that continues, who knows where it might lead?
22-08-2018, 10:03 AM #53
22-08-2018, 10:07 AM
#54
Cat required cars don't really stand much of a chance to pass without one anyway.
Over here its a federal offence to remove a cat off your car, for the owner and the garage doing the removal. This is in a country where in most states its legal to drive with 0 tread wear left on your tyres.
22-08-2018, 10:07 AM #54
Mr Reman
02-10-2018, 04:06 AM
#55
Now I'm getting a little worried.
My MX5 has 50mm spacers and glass fibre arch extensions. I cut the front arches back and formed a new lip (Non structural so shouldn't be an issue), But on the back I just flared them as far as I could for the time being. I still don't have enough clearance on the rear arches to lower it as far as I want. I was going to trim them back, Form a new lip a couple of inches further out of the way, Add fresh metal where required and plug weld the outer arch to the stretched wheel tub (Plug welded so that I didn't overly strengthen the rear crumble zone. Then splatter the whole area with 1/2 inch thick of underseal so the MOTer can't see the lack of continuous weld around it).
Now it looks like that'll have me squealing like a lobster in hot water come MOT time.
I could pop my 25mm spacers back on to pass but that would still mean that I couldn't do the rear arches properly and drop my '5's belly to the tarmac.
The only other alternative could be possibly to anneal the original arches so I can stretch them even further, but I'm not really happy about the idea of softening bit's of a cars metalwork in the name of "Safety".
Anyway, All this talk of MOT's has got me thinking today would be a good time to go out and wire brush, treat and underseal the surface rust I spotted on the car's belly at the last MOT. I find my MOTer's less likely to prod at 6 month old underseal with road cr4p all over it than stuff that's still glossy and wet. :tongue_smilie:
Scotty B.
Mr Reman
02-10-2018, 04:06 AM #55
Scotty B.
Mr Reman
02-10-2018, 07:32 AM
#56
Mr Reman Anyway, All this talk of MOT's has got me thinking today would be a good time to go out and wire brush, treat and underseal the surface rust I spotted on the car's belly at the last MOT.
CR4P !!!!
It seems that the "Surface rust" I saw 8 months ago has been quite busy since then.
I found 2 little holes about 3" apart........ But after some more prodding with a screwdriver I now only have one hole, But it's about 4" long.
Oh well, Looks like I'll need to break out my welder again to get next years ticket.:Sulk:
What are IS200's like for rust?
Scotty B.
Mr Reman
02-10-2018, 07:32 AM #56
CR4P !!!!
Scotty B.
02-10-2018, 08:03 AM
#57
IS200's are good for rust, meaning its not an issue. I think they have galvanised shells that helps a lot.
02-10-2018, 08:03 AM #57
uncle bob
04-10-2018, 07:17 AM
#58
Mr Reman Now I'm getting a little worried.
Scotty B.
Scotty an option if you are worried, is to get your Mazda mot tested before the new year, that way you have a years breathing space to sort it out or sell it on Wink
uncle bob
04-10-2018, 07:17 AM #58
Scotty B.
 3 Guest(s)
 3 Guest(s)
