JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Help help help.............
Pages (8): Previous 14 5 6 7 8 Next
28-12-2016, 10:11 AM
#61
ormi 5pk788 will NOT fit peeps i try'd for over an hour!!!!
So would a 790 fit mate ??
Mine feels as if the hoses need a tighten up again and thought I'd do the belt also. Feels a bit sluggish and underpowered compared to how it usually goes
28-12-2016, 10:11 AM #61
#62
5PK790 is a tight fit but you can fit easily if you rotate the crankshaft while you are installing the belt. Also your sc pulley will not shear. It is not so tight to damage the pulley.
28-12-2016, 10:11 AM #62
28-12-2016, 10:16 AM
#63
yes a 790 will fit but i cant get one for love nor money i'm using a 800 the now,moley you'r belt is 5mm too big so its prob slipping a bit...
dimis how much are the 5pk790 belts were you are??and can you get them and poss send them over if we cover p&p??
28-12-2016, 10:16 AM #63
28-12-2016, 10:18 AM
#64
I think i got mine for 9euro. I am offshore now, but once i will be back to Athens i will check and let you know if there are more in stock.
28-12-2016, 10:18 AM #64
28-12-2016, 10:25 AM
#65
ormi yes a 790 will fit but i cant get one for love nor money i'm using a 800 the now,moley you'r belt is 5mm too big so its prob slipping a bit...
I've just looked today at a spare belt I've got that was 805, not looked at the one thats on the car :Bazza::Bazza:
28-12-2016, 10:25 AM #65
#66
Here is the belt that i fitted on my sc:
[Image: 2ag1177.jpg]
have you tried to search this brand in UK?
28-12-2016, 10:25 AM #66
28-12-2016, 10:29 AM
#67
cheers matey just find out how much in real money it is to buy and post and i'll sort you out sure moley will too.
28-12-2016, 10:29 AM #67
28-12-2016, 10:30 AM
#68
ok no problem
28-12-2016, 10:30 AM #68
ok no problem
28-12-2016, 10:36 AM
#69
just try'd get lots of web sites i cant read....
28-12-2016, 10:36 AM #69
rob
28-12-2016, 10:52 AM
#70
no need to rotate the crankshaft etc - remove the tensioner, fit the belt on the pulleys and then refit the tensioner, its far easier and no messing with forcing the belt on.
rob
28-12-2016, 10:52 AM #70
 4 Guest(s)
 4 Guest(s)
