JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Help help help.............
Pages (8): Previous 14 5 6 7 8
28-12-2016, 11:00 AM
#71
rob no need to rotate the crankshaft etc - remove the tensioner, fit the belt on the pulleys and then refit the tensioner, its far easier and no messing with forcing the belt on.
You might be right, i will try it next time. But there was no need to tight a lot the tensioner after i fitted the belt, so i am not sure if it is so easy. Did you try your method with the 5PK790 belt or with the 5PK800?
28-12-2016, 11:00 AM #71
rob
28-12-2016, 11:06 AM
#72
thats with a 800 belt but there is lots and lots of room so i uess a 790 should be ok also??
rob
28-12-2016, 11:06 AM #72
 3 Guest(s)
 3 Guest(s)
