JapCarForum Cars, Cars, Cars! General Car Maintenance Mazda RX-8 PZ mods to date
Pages (8): Previous 14 5 6 7 8
abactus
23-04-2017, 01:08 PM
#71
love you wheels Smile
abactus
23-04-2017, 01:08 PM #71
28-04-2017, 01:27 PM
#72
looking good matey.....the wee boy from my work just collected his from aberdeen(hes 22)lovely cars..........they are the same as the lex fuel wise.....poooop round towns ok on long runs...
bobby underdrive pullys wont do anything for you mate well they will it'll make your steering a biy heavyer,alternator wont charge as much...only really for a high state of tune engine.....
bobby you adding oil to the fuel when you fill up??(as in putting oil in the fuel tank)
28-04-2017, 01:27 PM #72
28-04-2017, 01:31 PM
#73
ormi bobby you adding oil to the fuel when you fill up??(as in putting oil in the fuel tank)
Why would he do that ?????????????????
28-04-2017, 01:31 PM #73
28-04-2017, 01:40 PM
#74
its a wankle engine and doesn't use pistons it uses triangle shaped rotors and instead of piston rings it has carbon tips the tips wear down really quick if theirs not enough oil so by adding a small amount of oil to the fuel(just like the old two stroke motor bikes) it helps reduce the wear of the carbon tips......
thats straight from a tec from mazda its also on the mazda owners club..
28-04-2017, 01:40 PM #74
Bobby
29-04-2017, 06:55 AM
#75
Ormi, never heard of that before (oil with the petrol) not mentioned on the RX8 forums. I know there are additives some suggest but nope, just use good old Shell V-tec.
As for the advice on the underdrive pulleys, I was not planning on this but thanks for the info. Engine and handling there is not much more I can do as I am pleased with both as they are, Prodrive suspension set up & 231 bhp = 9000rpm redline :w00t:
thanks
Edited 10-06-2010, 06:38 PM by Bobby.
Cheers
Bobby
Shy boys don't get sweeties.
Bobby
29-04-2017, 06:55 AM #75
thanks
Cheers
Bobby
russelllinn
29-04-2017, 08:52 AM
#76
all looking good bobby, I have not heard about putting the oil in the fuel itself as I looked into the RX8 for a while, what I did read was that you should check the oil every other fuel stop, but i also thought that that was when it was new and running in, they do use oil as you prob know..
[Image: AliceTrack-1.jpg]
Have a look at my Scooby project thread here
My garage
Subaru
russelllinn
29-04-2017, 08:52 AM #76
My garage
Subaru
29-04-2017, 12:07 PM
#77
did you also know the prop shaft is carbonfiber on uk cars but steel all other places
29-04-2017, 12:07 PM #77
 3 Guest(s)
 3 Guest(s)
Views 2,412
06-12-2018, 12:58 AM
Last Post by speedview
Views 1,460
09-09-2018, 05:15 AM
Last Post by Jaminglish
Views 685
15-12-2017, 03:59 AM
Last Post by Mikey
Views 3,700
09-07-2017, 06:22 AM
Last Post by Bobby
Views 634
09-02-2017, 11:08 PM
Last Post by abactus
Views 498
18-01-2017, 12:24 AM
Last Post by Bobby
Views 1,171
21-10-2016, 04:49 AM
Views 1,392
22-05-2016, 12:20 PM
Last Post by wheels-inmotion
Views 499
11-05-2016, 10:43 AM
Last Post by Anees
