JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications Cradle Measurements
Cradle Measurements
Cradle Measurements
Pages (9): Previous 15 6 7 8 9 Next
eogbaker
01-02-2019, 09:55 AM
#71
sprinter2012 Aah yes I've seen those before, but at £80 it's a bit OTT for a low boost SC installation.
surely it is all down to personal preference. If you want a kit which is pretty much identical to the TTE kit then you pay the £80. You will still be a good £1000 less than buying a second hand TTE kit.
If you want to just boost your car for as cheap as possible then yes get the elbow silicone will do and while you are at it there is no real need for an intercooler so there is more money saved.......
eogbaker
01-02-2019, 09:55 AM #71
01-02-2019, 09:58 AM
#72
True but the intercooler is looks also not just useful where a single pipe isn't plus silicone pipes can be matched to what ever colour you have under there.
Like said personnel choice but to have the majority of items without the 2k+ price tag
01-02-2019, 09:58 AM #72
01-02-2019, 10:02 AM
#73
eogbaker surely it is all down to personal preference. If you want a kit which is pretty much identical to the TTE kit then you pay the £80. You will still be a good £1000 less than buying a second hand TTE kit.
I was actually considering just running the pipework straight across from the charger to the throttle body myself, will save a LOT of time and money fiddling about with custom pipes and stuff.
Plus it means you don't even have to take the bumper off! :Shooting:
Edited 14-03-2012, 07:37 PM by sprinter2012.
01-02-2019, 10:02 AM #73
01-02-2019, 10:20 AM
#74
It's not a bad idea, but you could be best measuring the inlet temp as it could be detrimental to the car?
01-02-2019, 10:20 AM #74
01-02-2019, 10:25 AM
#75
Sparkystav It's not a bad idea, but you could be best measuring the inlet temp as it could be detrimental to the car?
I'm sure I read a thread by Jay_Russell where he took temps of his TTE kit intake temps before and after he upgraded his pulley. I'll see if I can find it as it might save me some time measuring it myself.
Edited 14-03-2012, 08:06 PM by sprinter2012.
01-02-2019, 10:25 AM #75
S1SOFT
11-02-2019, 12:28 PM
#76
Hi, everybody.
At once I will forgive forgiveness for my English, I know badly, I transport by means of the dictionary Sad.
I from Belarus. I want to put on the Lexus the compressor, but it is not so easy to find and buy TTE kit, price plus not so please. Read here subjects, saw that people try to copy TTE kit. Too it wanted to try, but as I understood the biggest problem of cradle, all can be solved the rest, even the problem with the air filter can be solved more simply.
And so I have to you a huge request who can share cradle sketch with the approximate sizes. At my place fastenings will make much cheaper, than to look for at you + delivery.
Thanks in advance.
S1SOFT
11-02-2019, 12:28 PM #76
Hi, everybody.
Thanks in advance.
11-02-2019, 12:36 PM
#77
hi mate, the issue is not the actual cradle size its more getting all the angles correct so the belt lines up with the pulleys
what is really needed to make and copy cradles is a jig
11-02-2019, 12:36 PM #77
S1SOFT
11-02-2019, 12:44 PM
#78
knowing the approximate sizes of a cradle, by means of good hands it is possible to make a cradle that the pulley and a belt were to one line.
Simply, without starting data to start to try to do a cradle not really.
Can at someone there are approximate sketches and the sizes. I will be very grateful
S1SOFT
11-02-2019, 12:44 PM #78
11-02-2019, 12:57 PM
#79
been trying to get them for a while but with no help so far mate,
its a difficult thing to try and get help for but dont give in
11-02-2019, 12:57 PM #79
lil_rob
02-01-2020, 04:13 PM
#80
I know this is a old thread but anyone managed to fabricate a craddle yet?
lil_rob
02-01-2020, 04:13 PM #80
 3 Guest(s)
 3 Guest(s)
Views 1,676
29-05-2023, 05:08 PM
Last Post by Mikedaddy
Views 409
02-12-2022, 01:57 PM
Views 806
17-09-2022, 01:50 AM
Last Post by captain
Replies 62
Views 2,809
05-06-2021, 12:09 AM
Replies 61
Views 3,198
23-01-2018, 02:52 PM
Last Post by dandydons
