My new toys
My new toys
Pages (177): Previous 180 81 82 83 84177 Next
30-08-2017, 02:25 AM
DimitrisTS Go to the online manual at: new car features -> Chassis -> Differential -> Helical Gear Type TORSEN LSD
This is a copy-paste from there:
"Ordinary differential oil must be used; do not use special LSD oil".
Also check at the Service Data Sheet. It says the same thing about the torsen type.
At my local Lexus service they also did use LSD oil but when i show them the toyota manual they began scratching their heads!
As you mentioned above the manual says "special". Probably the manual refers to not use lsd oil that is designed for racing/rallye cars but ordinary lsd oil for daily driving cars which have an lsd.
30-08-2017, 02:25 AM #811
DimitrisTS
30-08-2017, 02:37 AM
In the service data sheet the manufacturer says that the same type of oil is to be used for both differentials. And that is API GL5 SAE90, SAE80W or SAE80W-90.
I am using ordinary and not lsd oil for my car for about 60.000 km now and its working as it should.
Those "LSD" differentials are not true Torsen. They are Torsen type with a different principle of function. They are based to the friction between oil, gears and the differential case. That has the benefit of almost zero wear but also they do not have the precision that other true Torsen or other type of LSD have.
I don't think that puting LSD oil will do any damage but i am sure that your differential will not "limit the slip" as it should.
That's my point of view anyway...
DimitrisTS
30-08-2017, 02:37 AM #812
30-08-2017, 02:52 AM
DimitrisTS In the service data sheet the manufacturer says that the same type of oil is to be used for both differentials. And that is API GL5 SAE90, SAE80W or SAE80W-90.
The motul 90PA i have used is a API GL5 SAE90.
have a look:
http://www.pdm-racing.com/products/motuloil.html
so no worries, everyone is happy Big GriniscoStu:
30-08-2017, 02:52 AM #813
have a look:
30-08-2017, 03:00 AM
Here is the specifications of Motul 90PA
http://www.opieoils.co.uk/pdfs/MOTUL/90-...8GB%29.pdf
taken from opie oils website.
AS you see this LSD oil is a API GL5 SAE90, as written in the Lexus manual.
30-08-2017, 03:00 AM #814
30-08-2017, 04:32 AM
I started looking and searching today in the web for ideal aftermarket ecu's for my project. I fell into this ecu which i found quite interesting and i think it will work ok for my little project. -> AEM FIC, it is a paralled ecu that works paralled with the factory ecu of the car. From the video i saw it has a very friendly interface and the manual explains well what and how to do.
http://www.youtube.com/watch?v=Hu_GT5aCxwg
has any of you used or has any relative experience with this product? Any help or suggestions would be a big help for me. Never played with aftermarket ecu's before so i am entering a new field.
Can i say it is similar product with a Greddy emange blue or ultimate?
30-08-2017, 04:32 AM #815
04-09-2017, 08:13 AM
The Denso 310cc injectors arrived and today i did a good cleaning with WD40.
[Image: thumb_fersnesjsjlnkufrf4nl3nlf8s.jpg]
[Image: thumb_s2fs2n2snfr2s22nre392j3n2n.jpg]
I just have to order a repair kit to change the o-rings and the filters.
04-09-2017, 08:13 AM #816
04-09-2017, 09:46 AM
looking good mate.
04-09-2017, 09:46 AM #817
looking good mate.
04-09-2017, 10:08 AM
will be nice to see how much you will get out of them.
04-09-2017, 10:08 AM #818
05-09-2017, 10:28 AM
For anyone who is interested for this Denso injector the part number is: 23250-22030
Found some information regarding the upgrade of the fuel injectors for the IS200. The altezza motor (3SGE) uses 340cc Denso injectors.
Here are the specs:
Specs:
Colour - White
Flow - 340cc
Pintle Holes - 6
Resistance - 14 Ohms (High impedance)
Denso number - 23250-74220 (Toyota number 23209-74220)
More specs:
@ 14V:
(Duration @ 14V / Pressure @ kg/cm2 / flow @ cc/min
0.76ms / 2.55cm2 / 340cc
0.76ms / 3.05cm2 / 370cc
0.78ms / 3.55cm2 / 400cc
05-09-2017, 10:28 AM #819
Here are the specs:
Specs:
Colour - White
Flow - 340cc
Pintle Holes - 6
More specs:
@ 14V:
07-09-2017, 10:44 AM
It is time to change tyres so today it was a good day to drift!!!! :taz:, and record of course videos. Below is a good one. I hope you like it:
http://www.youtube.com/watch?v=kvdv4y1TwaQ
07-09-2017, 10:44 AM #820
 5 Guest(s)
 5 Guest(s)
