JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications Supercharger to Turbo Swap
Pages (6): Previous 1 2 3 4 5 6 Next
iano21
15-04-2017, 11:41 AM
well ill get the story out clear up for ye. . but keep it to point ha. i started by putting a turbo on my is200 got all mechanical done and brought it to get mapped got messed around by few lads and eventually got what was supposed to be right. your man who done wiring for me (did everything myself besides wire emanage) engine blew up on way home from mapper. left it in bits :Shooting:
but that engine he said was not idiling right blaming **** emanage and fault in throttle body. so put in new engine and throttle body and got her going week ago. but still not running right.
it is idling at 11/12 hundred revs and boppy on exhaust like overfueling or so on so on. . think badly mapped :cursing: talked to few lads and they say for my setup which was close to 250BHP at 0.6 boost the 550 injectors are too big and standard ones to small. . that there will always be slight idling hick ups but i dont know and lots of lads are very happy with the way theres turned out. . so half thinking of bringing it over there and give ye a chance Confusedcared: lol.
and thanks for all the help marc, steve, everyone ye all been great help
iano21
15-04-2017, 11:41 AM #21
iano21
15-04-2017, 11:56 AM
here some pics for ye. . and small spec list
garrett T28 BB turbo with cast manifold and heat shield + braided oil and water supplies,
full stainless exhaust with HKS HiPower back box,
front mount intercooler with SFS hoses,
PE 550 injectors + sard fuel pressure reg, walboro fuel pump,
fuel return line and braaided hoses,
greddy emanage + greddy boost gauge,
D1 oil catch can, induction kit, SFS engine hose kit,
C-One rad panel ( not in these pics) mocal oil cooler,
HKS black edition dump valve, blitz SBCID boost controller, HKS radiator and oil cap,
outside of that Driftworks HSD coilovers, grooved brake discs and red stuff pads, etc etc wont bore ye ha
probably forgetting few bits
.jpg
.jpg
.jpg
iano21
15-04-2017, 11:56 AM #22
.jpg
.jpg
.jpg
Crysec
15-04-2017, 12:16 PM
http://www.gtsparkplugs.com/InjectorSizeCalc.html
I got 495cc / min from that calculator for a 250 BHP car.
Everything is as nothing does.
Crysec
15-04-2017, 12:16 PM #23
15-04-2017, 12:21 PM
Have you got a wideband in mate? could link that to the emanage? that could help a lot
15-04-2017, 12:21 PM #24
Crysec
I don't know much but a fuel pump with less pressure? If you could reduce it to 35psi, would match.
Crysec
15-04-2017, 12:21 PM #25
iano21
15-04-2017, 12:25 PM
no nothin like that you mean get the greddy one to plug into emanage option port?
iano21
15-04-2017, 12:25 PM #26
iano21
15-04-2017, 12:29 PM
well dont think that would matter i have return line in so the fuel pressure reg can set the pressure dumps the rest back into tank
iano21
15-04-2017, 12:29 PM #27
iano21
15-04-2017, 12:30 PM
Marsdendean I hope you get it sorted. Steve had an AFR meter to check everything was OK on the fueling side, think that saved him from a slight problem he was having?
ya couple of lads were saying that i might get my hands on one thanx
iano21
15-04-2017, 12:30 PM #28
15-04-2017, 12:56 PM
Well any will plug into the emanage mate, most have a serial output on, i have a AEM one
15-04-2017, 12:56 PM #29
15-04-2017, 10:28 PM
On the injectors, the standard ones would probably be ok at 250bhp, but pretty close to their limit. I am running 257bhp but put in the 550cc injectors to be on the safe side, since one of the aims of my project was to stick very much on the side of safety, not to run right close to the limit.
550cc injectors are, I think, with hindsight, a bit bigger than they need to be for that sort of power, but then again I'm not sure what the alternative is. I think that Jamie is/was running with injectors of 330cc or so, and I don't know which cars those came from, but I believe they had a different number of holes for the fuel delivery compared to the OEM injectors - and I really didn't like the sound of changing something like that, personally.
As I said to Ian via PM, my car idles fine, at the right sort of speed (around 650rpm).
With the e-Manage Ultimate, you can tell it a new size of injector compared to the original injectors, and it automatically works all the fuelling out for you. Actually I found out that isn't how my map was done by Noble, they effectively did the fuelling "manually".
15-04-2017, 10:28 PM #30
 8 Guest(s)
 8 Guest(s)
Views 1,773
29-05-2023, 05:08 PM
Last Post by Mikedaddy
Views 758
23-05-2023, 12:26 AM
Last Post by ashj25839
Views 791
17-04-2023, 03:51 AM
Views 492
06-04-2023, 02:00 AM
Replies 24
Views 1,040
12-01-2023, 11:53 AM
Views 143
03-01-2023, 01:19 PM
Views 114
27-12-2022, 10:58 PM
Views 440
02-12-2022, 01:57 PM
Views 268
29-11-2022, 03:38 AM
Last Post by phaebo
