Leaking
Leaking
Has anyone got problems with their boot/trunk leaking? Mine is leaking on the R/H side, and high uo ( not around the lights) This is puzzling me though, as I have not washed the car for a few weeks, yet its wet and there was no rain fall... Help
I did have a leak on the passenger side in the same area, I took the seal off and siliconed it then pump the seal back on
They go down to below the boot floor though in the side of it
Do you know if they're metal or plastic and do they have any joins between the sunroofs drip tray and where they exit ?
I'm just wondering if they could get damaged on sharp edges or rust through.
As I said, This idea could be wildly off the mark, but it's still an idea.
Scotty B.
jomo I think the sunroof drain pipes are all in one long plastic tube with out joints.OK, Can you think of anywhere in the c-post area where they could chafe on an edge (I haven't had enough of my IS200 apart yet to know this myself)?
Thanks for all the responses guys. I think I've have found the problem. The car was repaired on the drivers side, (I think a new rear wing was fitted) and it was not sealed properly.
