JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Rusty sunroof :Sulk:
gazzarose
12-02-2019, 11:18 AM
Hi guys,
Noticed a while ago, the inside front lip of my sunroof is going rotten. I did think about rubbing it down and trying to spray it, but don't fancy doing it in the car, so would have to take it out, and to be honest I think it might be too far gone to respray. I've had a look on ebay and quite often theres a sunroof mech for around £50, which isnt too bad, question is how hard is it to change. The roof lining would need to come down, but Im guessing that the lining wont come all the way out with the windscreen in. Has anyone had to swap one? Maybe even swapping one cos of a knackered mech, but still got a good glass and surround I could relieve them of for a a few beer tokens?
Annoyingly I've never been able to find a leak so can only think the water is coming in between the glass and the rubber.
Any help would be much appreciated.
Thanks
Gareth
gazzarose
12-02-2019, 11:18 AM #1
Hi guys,
Thanks
Gareth
lex2oos
12-02-2019, 10:16 PM
roof lining can be removed with no probs...
lex2oos
12-02-2019, 10:16 PM #2
Mikey
13-02-2019, 01:58 AM
first off remove all the inside pillars then the map and centre light then grab handles then the rooflining should come down but hard to get out the door with out bending a little.
Mikey
13-02-2019, 01:58 AM #3
13-02-2019, 03:24 AM
Mikey first off remove all the inside pillars then the map and centre light then grab handles then the rooflining should come down but hard to get out the door with out bending a little.
Do you actually need to get it out of the door? If it is loose I would have thought you could fit the new mechanism with it still in the car?
13-02-2019, 03:24 AM #4
Mikey
13-02-2019, 04:34 AM
the sunroof assembly is quite big you have got to remember where it goes when you slide it open you could just possibly lean the front seats right back so they are quite flat an just rest the lining there, but it would be awkward getting in the car to get the assembly down without damaging the lining.
Mikey
13-02-2019, 04:34 AM #5
13-02-2019, 07:47 AM
you know that lexus has a 12 year rust warranty. check if it's still covered. but i think it needs to be a hole in it
13-02-2019, 07:47 AM #6
Jaminglish
13-02-2019, 08:02 AM
My lexus is only ten years old. Do I take it back to lexus? Have some rust in the door shuts..
Jaminglish
13-02-2019, 08:02 AM #7
13-02-2019, 08:20 AM
yes
13-02-2019, 08:20 AM #8
yes
gazzarose
15-02-2019, 11:25 AM
Im pretty sure the 12 yr corrosion warranty only covers sheet metal, not things connected to it, ie bumpers and things. At I know now I can drop the headlining to get the sunroof out. Ill keep eye out on ebay for one.
Thanks for the replies guys
Gareth
gazzarose
15-02-2019, 11:25 AM #9
Gareth
Views 370
17-11-2018, 01:10 AM
Last Post by jomo
Views 582
19-03-2018, 01:12 AM
