JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Engine & Transmission Ecu speed
Ecu speed
Ecu speed
168
13-02-2019, 12:37 AM
Not sure if this comes up in the Engine section but I'm looking at using dashcommand with a wifi obd adapter.
Now i gather that the refresh rate and lag depends massively on the speed of the ecu, and that Toyota Ecu's are some of the fastest, but does anyone know how much lag I'm likely to get?
I'll be using an Iphone 4, displayed on the Pioneer Appradio, via Obd Wifi.
Does anyone else have experience of any of the above?
northernmonkey
13-02-2019, 12:37 AM #1
13-02-2019, 09:48 AM
why not buy one of the units from the seller on here. i think he had a test section for them as i got mine from here. http://www.speedview.co
13-02-2019, 09:48 AM #2
lex2oos
13-02-2019, 11:17 AM
IIRC it uses ISO9141-2 protocol... thats all i can say. I have tested Torque and HobDrive software on Android and Windows mobile with cheap ebay bluetooth elm327 adapter and they both ar kinda slow... not sure if its ecu's or adapters fault, sorry...
lex2oos
13-02-2019, 11:17 AM #3
13-02-2019, 11:48 AM
Most likely the OBD adaptor. The scantool.net and PLX devices can read over 60 PIDs per second. Other adaptors are slower.
13-02-2019, 11:48 AM #4
168
13-02-2019, 11:52 AM
toxo Most likely the OBD adaptor. The scantool.net and PLX devices can read over 60 PIDs per second. Other adaptors are slower.
That's what i was get at, I've tried it with a bluetooth adapter and the refresh rate was fairly slow, but I didn't know if it was the adapter or the ecu.
I'm loathed to chuck more money at a wifi adapter if it's still gonna be god slow.
I'll be using an iphone 4 and dash command.
northernmonkey
13-02-2019, 11:52 AM #5
P.Lindblom
13-02-2019, 12:25 PM
lex2oos IIRC it uses ISO9141-2 protocol... thats all i can say.
I'm pretty sure that's the slowest OBD2 protocol.
P.Lindblom
13-02-2019, 12:25 PM #6
lex2oos
13-02-2019, 09:45 PM
I wonder if cars from 2004 year still had the same protocol. its fairly old and slow. I wonder if they changed anyting in the last models...
lex2oos
13-02-2019, 09:45 PM #7
