JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications supercharger Belt problems!
164
23-02-2019, 03:55 AM
I fix on thing then somthing else happens!
ok so refurbed my charger, runs so much nicer, problem now is belt just destroying!
[Image: 561345_10151467736140500_574495499_23439...6557_n.jpg]
ok so running a 800 belt like i had before, got new belt after day of driving started making noise looked and had done this, so refit old belt after 5min of driving it did this! so before i refurbed was fine never did this but, affter refurbing and securing the bracket bit better noticed when i went to put the old belt on especially, that i could push the tensioner to its max before had about 2mm on left side of the bolt now non and seem when runing to be slack! on the long side i and twist the belt 180 and there is like 5-10mm bounch in the belt.
so what i want to know is, is my charger fine and will a smaller belt help 790? as i notice most of you seem to be running that anyway, but dose the belt being slack explain why it ripped? as already gone through 2 belts in 2 days dont want it to do same on the smaller belts!
I looked as it was running pully looks fine no movement noticed cuz i cut the ripped bit of a belt just to run it 4pk noticed put it in normal position as if it was a 5pk and ran it when it ran over 4-5k engine rpm it jumped forward.
just want it to be easy fix, so many things just going wrong at the min Sad
lookatmybiceps
23-02-2019, 03:55 AM #1
23-02-2019, 04:02 AM
i would think its to do with being slack and its slapping against itself or the pulley.
i would try the smaller belt and see what happens with it then.
just to point out i dont have a charger but as said i think it may be slack
23-02-2019, 04:02 AM #2
23-02-2019, 09:42 AM
Could have been a faulty belt the new one, and the old one just old and stretched?
23-02-2019, 09:42 AM #3
24-02-2019, 05:29 AM
ok i think my new bit of bracket has lifted the charger at the back making the belts slack, put washers on front of charger to lift it up n bring it back aligned and the 800 belt is tight like before! so will see how it goes.
lookatmybiceps
24-02-2019, 05:29 AM #4
Views 1,675
29-05-2023, 05:08 PM
Last Post by Mikedaddy
Views 710
23-05-2023, 12:26 AM
Last Post by ashj25839
Views 468
06-04-2023, 02:00 AM
Replies 24
Views 916
12-01-2023, 11:53 AM
Views 110
03-01-2023, 01:19 PM
Views 85
27-12-2022, 10:58 PM
Views 408
02-12-2022, 01:57 PM
Views 421
04-11-2022, 05:54 AM
Views 58
30-07-2022, 01:49 PM
