JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza what could it be? tyres? barkes?
wahidhussain
25-02-2019, 02:15 PM
hi all
Alright, at first I just thought that my tires needed air, but even since I put air in them this problem has gotten worse.
You know how it feels when you go down a bumpy road? cars tend to follow the road... in a bad way? Like when you come over the crown of the road, it redirects? Like the wobble back and fourth with bumps?
im running 225/40/18
3 with 6mm+ tread and one with less then 3mm which is on the front passenger side
wheels are rx450h wheels with et35
things i had changed in the last 6 months are
inner and outter tie rods
upper balljoints
lower balljoints
lower control arm bushes
caster bushes
and Alignment done by wheels in motion
it passed its mot just last week
thanks in advance guys
wahid
wahidhussain
25-02-2019, 02:15 PM #1
hi all
upper balljoints
lower balljoints
caster bushes
wahid
25-02-2019, 02:39 PM
you could try swapping the fronts with the rears wouldnt hurt to see if theres any difference if you think its tyre related, you may of lost a ballencing weight off a wheel? or it could be a sticky calliper?
25-02-2019, 02:39 PM #2
wahidhussain
25-02-2019, 03:51 PM
hi mate
will give that a try never thought of that
thanks for the reply mate
wahid
wahidhussain
25-02-2019, 03:51 PM #3
hi mate
wahid
26-02-2019, 02:29 AM
no probs dude thats what were here for keep us updated
26-02-2019, 02:29 AM #4
E55EX_RACER
27-02-2019, 09:47 AM
Sounds like you're describing tramlining. What brand are the tyres?
E55EX_RACER
27-02-2019, 09:47 AM #5
wahidhussain
27-02-2019, 10:09 AM
hi guys
update
did the change and must it has made a difference but i need to see in the week to confirm
E55EX_RACER Sounds like you're describing tramlining. What brand are the tyres?
hi mate
tyres are
3 nankang ns2 ultra sport with 5/6mm tread v grove tyres
and one dunlop sp sport maxx with less then 3mm tread straight grove tyre
the dunlop was on the front but know on the rear
thanks
wahid
wahidhussain
27-02-2019, 10:09 AM #6
hi guys
update
hi mate
tyres are
thanks
wahid
27-02-2019, 12:29 PM
scrap the dunlop and get the 4th nankang
27-02-2019, 12:29 PM #7
wahidhussain
27-02-2019, 12:56 PM
is300_dino scrap the dunlop and get the 4th nankang
hi mate
i am thinking of changing the fronts to 215/40/18 anyway
on that note can you do that on a lexus? i know you could change tyre sizes on the bmws
im thinking front 215/40/18
and 225/40/18 rear would that make any difference to handling? i mean in a bad way?
thanks again mate
wahid
wahidhussain
27-02-2019, 12:56 PM #8
hi mate
thanks again mate
wahid
27-02-2019, 11:08 PM
i run 225/40/18 on all corners, not sure what your planned setup would be like on the handling front, im sure someones probably tried it.
27-02-2019, 11:08 PM #9
wahidhussain
28-02-2019, 09:11 AM
is300_dino i run 225/40/18 on all corners, not sure what your planned setup would be like on the handling front, im sure someones probably tried it.
all standard set up mate
thanks
wahid
wahidhussain
28-02-2019, 09:11 AM #10
thanks
wahid
Views 690
02-03-2019, 06:45 AM
Last Post by Bandit
Replies 23
Views 1,373
22-09-2017, 12:15 PM
Last Post by E55EX_RACER
Views 470
17-08-2017, 11:46 AM
Views 469
27-05-2017, 03:35 AM
Last Post by link005
Views 737
19-02-2017, 07:42 AM
Last Post by spikes
