JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza bigger injectors ! 1gfe
jameshunter
27-03-2020, 02:30 PM
this might seam to be a stupid question but what would be the outcome if i uprated the injectors in my standerd 1gfe engine to say 550cc and would i need any outher parts for instance regulator
any help would be grate
jameshunter
27-03-2020, 02:30 PM #1
27-03-2020, 02:43 PM
you need to manage the new injectors with a piggyback ecu or other type. cant see why you would want to do this as the original ones will go to about 220 bhp without problems. the only reason for putting new ones in is if your running a turbo.
27-03-2020, 02:43 PM #2
27-03-2020, 03:55 PM
You have to remember injectors are controlled by amount of time they fire for, not the volume passing through.
So they would work but your engine would run very very rich.
27-03-2020, 03:55 PM #3
LEX11S
10-04-2020, 08:52 AM
dont think you want to change the injectors unless your fitting a turbo or supercharger kit but the std ones can go to around the 270hp mark i know this because thats what my car was running with std injectors and fuel pressure reg
LEX11S
10-04-2020, 08:52 AM #4
Replies 18
Views 2,349
14-10-2021, 06:22 PM
Last Post by Danies200
Views 1,071
24-06-2021, 07:53 PM
Last Post by Lance79
Views 1,365
10-01-2021, 06:04 AM
Last Post by ozzie b
