JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Engine & Transmission new radiator
new radiator
new radiator
buzzard2011
08-04-2019, 08:05 AM
hi,
i need a new radiator,got a big hole in mine?leaking everywhere.anyway ive seen plenty on flea bay so should be ok?.
however will i need to regass my air con afterwards? as it looks to me that the air con pipes come from the bottom of the rad,any info on how to change or possible problems when changing the radiator would be greatly appreciated.
many thanks.
buzzard2011
08-04-2019, 08:05 AM #1
hi,
many thanks.
08-04-2019, 08:35 AM
i think the ac has it's own rad so i think you can remove the normal rad and leave the ac one there. but not 100% on that
08-04-2019, 08:35 AM #2
Phil01
08-04-2019, 08:40 AM
if you have pipes going into/out of bottom of rad you must have an auto, these is the cooler feed pipes
Phil01
08-04-2019, 08:40 AM #3
08-04-2019, 08:58 AM
no need to change the aircon, simple job to change the rad, an hour tops including refilling the system
08-04-2019, 08:58 AM #4
buzzard2011
09-04-2019, 12:57 AM
cheers guys always there to help. appreciate it.
i think the loop that runs from the left hand side is the air con cooler,so no probs with that,but i have a small pipe that bolted on to the bottom right side as well,dont know what this is,and if i take it off dont know what will gush out?:confused1:
i will give it a go and see haha.
its a manual 2001 sport if this helps.
thanks.
buzzard2011
09-04-2019, 12:57 AM #5
thanks.
09-04-2019, 01:34 AM
Get some pics up mate
09-04-2019, 01:34 AM #6
buzzard2011
09-04-2019, 01:55 AM
cheers sparky,
ill try soon,just been reading a bit and it seems you can fit an auto one in a manual,you just dont need the cooler lines for the auto transmission.
if this is the case ill get one as they are a bit cheeper for some reason?
buzzard2011
09-04-2019, 01:55 AM #7
cheers sparky,
buzzard2011
09-04-2019, 02:28 AM
the two bracketts one upper and one lower,maybee just there to hold the pipes on,no gases?[Image: 7232695684_2736cf86b1_m.jpg]
Picture 711 by terbert2009, on Flickr
buzzard2011
09-04-2019, 02:28 AM #8
buzzard2011
09-04-2019, 03:12 AM
ok,have got it sussed now,i need 2 rads lmao,the thin front one is the air con,as its just ****** gas all over my leg and frozen my knee!!!!
the main one is behind this,****** anyway have took it all off now so will need to look for 2 new ones,jeez skint again:angry:
buzzard2011
09-04-2019, 03:12 AM #9
09-04-2019, 05:24 AM
sorry just seen this, yes the front ones the aircon one, the back ones the water/coolant one.
the aircon one isnt cheap im afraid.
09-04-2019, 05:24 AM #10
Views 271
21-05-2019, 09:52 AM
Last Post by Ji123
Replies 74
Views 3,089
18-02-2017, 11:57 PM
Last Post by James S
