JapCarForum Cars, Cars, Cars! General Car Maintenance '04 Lexus SC430 Oxygen sensor replacement
cth
13-04-2019, 10:21 AM
My Check Engine/vsc Lights Are On, Placed On Computer To Test, & It Says "Heated Oxygen Sensor"...
However, there are three (3) Oxygen sensors & the computer won't say which one?!?!? Any suggestions, other than having to pay a shop to check all three? My concern is also whether this is the true malfunction (with VSC light on) or possibly another part, since light comes on for multiple issues...
cth
13-04-2019, 10:21 AM #1
mattlaw
13-04-2019, 11:45 AM
What is the fault code as they all go to specific sensors? Also you'll find you have four sensors on an sc430
mattlaw
13-04-2019, 11:45 AM #2
13-04-2019, 12:17 PM
Once you have the code, this should help:
http://www.toyotapart.com/Engine_Bank_1_...398-09.pdf
13-04-2019, 12:17 PM #3
mattlaw
13-04-2019, 12:32 PM
Ooooh I like that link,
mattlaw
13-04-2019, 12:32 PM #4
cth
13-04-2019, 05:13 PM
Thanks for the quick response. I went to Auto Zone & Advance Auto Parts to have them test with their computer. They both came up with Heated Oxygen Sensor - but didn't appear to have a specific code differentiating which sensor was bad? It gave the sensor to replace as #17533 (I think), but that was the same # for whether it was the "upstream" or "downstream" sensor, with I believe the downstream needing two (2) sensors replaced... Anyway a layman can determine whether upstream or down sensors?
cth
13-04-2019, 05:13 PM #5
13-04-2019, 11:49 PM
The computer should've given you a code somewhere between P0130 and P0167 to indicate which sensor it is (and more details on what the fault is).
13-04-2019, 11:49 PM #6
mattlaw
14-04-2019, 08:20 AM
Where abouts are you based? If you're near Manchester ill read the codes for you
mattlaw
14-04-2019, 08:20 AM #7
cth
14-04-2019, 10:19 AM
I'm in So Florida, but thanks for the offer. I'm going back to Auto Zone & have them re-do the test to see if it illustrates the P0130-0167. I hope so!
cth
14-04-2019, 10:19 AM #8
14-04-2019, 10:28 AM
Lol that would be a bit of a trek. Might be worth printing that PDF and taking it with you?
14-04-2019, 10:28 AM #9
cth
14-04-2019, 12:42 PM
Turned out it was code P031, which they've determined it's Bank 1, Sensor 1... They recommend I replace both the upstream sensors, saying if one goes, the 2nd is apt to be right behind it. Are they step-selling me to buy another sensor (of course the 2nd one is a more expensive side), or do you recommend replacing both at the same time?
I'm assuming Bank 1 would be the driver's side sensor?
Thanks for the advice!
cth
14-04-2019, 12:42 PM #10
Views 339
09-11-2023, 11:04 AM
Last Post by Keeperlit19
Views 981
07-12-2021, 09:23 AM
Last Post by reganlives
Views 1,503
09-11-2021, 02:37 AM
Last Post by Dinho
Views 865
28-01-2021, 06:18 AM
Last Post by 1374lee
Views 888
29-08-2020, 11:20 AM
Views 567
03-05-2019, 11:23 PM
Views 756
19-10-2018, 02:01 PM
Replies 18
Views 1,561
24-11-2017, 07:13 PM
Last Post by D6NGR..
Views 11,346
09-09-2017, 12:26 PM
Views 1,091
17-07-2017, 02:02 PM
