JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications New Clutch, Uprated?
164
17-04-2019, 05:26 AM
Hi
ok its been going for a while and ive know just been putting it off but after remap and using all the engine power now in 6gear at high speed then trying to go faster starting to slip!
What should i get just new clutch? or uprated one?
i dont want to cheap out and it just ruin an oem clutch fast but ive seen some which look so excesive for the power im running, just wandering what clutches most of you with superchargers have as long weekend coming up so want to try and order one and get it done then.
lookatmybiceps
17-04-2019, 05:26 AM #1
Hi
17-04-2019, 07:06 AM
I still have the standard Toyota one in my car!
17-04-2019, 07:06 AM #2
spud1973
17-04-2019, 07:35 AM
Running a standard on mine aswell no issues
spud1973
17-04-2019, 07:35 AM #3
posty
17-04-2019, 07:57 AM
Standard in mine, and all running fine and dandy.
posty
17-04-2019, 07:57 AM #4
164
17-04-2019, 09:48 AM
Sparkystav I still have the standard Toyota one in my car!
Really!
Seems To be ok then will get a standard one if it good enough!
lookatmybiceps
17-04-2019, 09:48 AM #5
Really!
17-04-2019, 10:00 AM
well im using the 1ggte which is maybe a cm bigger in diameter than the 1gfe one but made of the same stuff!
17-04-2019, 10:00 AM #6
17-04-2019, 10:27 AM
also anyone fitted one got any tips? only ever done clutch change on old FF cars with cable n little gearboxes so quite easy, the gearbox looks quite heavy on the lexus if im led under dont wanna get crushed! lol.
lookatmybiceps
17-04-2019, 10:27 AM #7
17-04-2019, 11:47 AM
The top bolts are a PITA to get to, I believe a long extension or 2 and a UJ attachment is needed. Some people say you can get the bolts from the top? Wayne did mine from the bottom - all done in 2 hours - on a proper lift I may add.
17-04-2019, 11:47 AM #8
S
17-04-2019, 01:47 PM
FirebirdPhil The top bolts are a PITA to get to, I believe a long extension or 2 and a UJ attachment is needed. Some people say you can get the bolts from the top? Wayne did mine from the bottom - all done in 2 hours - on a proper lift I may add.
The man speak truth! I did mine on my drive and it was horrendous! You need LOTS of extension bars to get the top bolts.
S
17-04-2019, 01:47 PM #9
spud1973
18-04-2019, 07:37 AM
Agreed lots of extension for the top bolts and make sure all the wiring is out of the way when putting it back together I managed to trap the wire for the speedo.
spud1973
18-04-2019, 07:37 AM #10
Views 1,269
05-04-2023, 03:19 AM
Last Post by damtrx
Views 228
27-02-2021, 01:49 PM
Last Post by lexusdaydreaming
Views 356
26-02-2021, 11:11 AM
Views 448
25-11-2019, 02:05 PM
Last Post by Jon
Views 472
17-12-2018, 10:18 AM
Last Post by S
Views 416
06-11-2017, 01:15 PM
