JapCarForum Trade Area Trade Archive Selling Archive Vacuum bypass valve for TTE supercharger
rob
02-05-2019, 09:36 AM
hi,
I have a vacuum operated bypass valve that fits the TTE supercharger unit without any modification.
Simply unbolt you old cable operated one and bolt in this one.
When I had it on the car it provided a huge performance increase as the bypass fully closes and boost pressure started to increase as soon as you touched the throttle.
I had to remove it when i registered the car in switzerland.
To use this valve you will need to connect it to the vacuum line next to the throttle body.
[Image: 3306wzo.jpg]
valve is in perfect working order, i could easily say its in "as new" condition.
£95 posted.
rob
02-05-2019, 09:36 AM #1
hi,
£95 posted.
02-05-2019, 11:46 AM
How much is huge?
02-05-2019, 11:46 AM #2
How much is huge?
rob
02-05-2019, 12:23 PM
cant give any figures, its just what i and passengers felt in a before and after drive.
As soon as you touch the throttle the bypass closes so the pressure builds immediately rather than having to put your foot to the floor.
rob
02-05-2019, 12:23 PM #3
Campy
04-05-2019, 08:30 PM
Hi don't suppose you still have the bypass valve do you, I'm still running the original setup and am very interested
Campy
04-05-2019, 08:30 PM #4
buzzard2011
04-05-2019, 10:10 PM
maybee this would work,looks the same set up?
BMW MINI Cooper S Supercharger Bypass Valve by-pass R53 R52 by pass r52 r53
buzzard2011
04-05-2019, 10:10 PM #5
rob
04-05-2019, 10:24 PM
Campy Hi don't suppose you still have the bypass valve do you, I'm still running the original setup and am very interested
Sorry, I had a message yesterday from someone that will take it.
buzzard2011 maybee this would work,looks the same set up?
similar but it wont fit as the arm on the actuator is the incorrect length
rob
04-05-2019, 10:24 PM #6
Campy
04-05-2019, 10:56 PM
Don't suppose you could tell me how you found yours?
Campy
04-05-2019, 10:56 PM #7
05-05-2019, 12:34 AM
I actually have 2 of these at home, without the valve part but i fitted one to my tte charger using the existing parts, did work very well.
05-05-2019, 12:34 AM #8
rob
05-05-2019, 12:47 AM
Campy Don't suppose you could tell me how you found yours?
I was in the USA and walked past a tuning shop that had turbos, superchargers etc in the window along with the bypass valve.
rob
05-05-2019, 12:47 AM #9
Campy
05-05-2019, 01:35 AM
Bummer, but cheers anyhow, I'll keep hunting
Campy
05-05-2019, 01:35 AM #10
Views 299
23-08-2020, 10:16 AM
Views 245
03-04-2020, 10:11 AM
Last Post by S
Replies 24
Views 1,269
24-01-2020, 02:53 PM
Last Post by S
Views 200
01-12-2019, 11:19 AM
Last Post by sprinter2012
Views 1,045
15-10-2019, 08:11 AM
Last Post by micromarc
Views 886
17-08-2019, 06:08 AM
Last Post by JayJay1374
Replies 24
Views 3,264
01-08-2019, 04:26 AM
