JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Engine & Transmission Overheating
Overheating
Overheating
Pages (4): 1 2 3 4 Next
reganlives
05-05-2019, 10:32 AM
I've noticed recently that my cars overheating. I checked it last weekend and everything seemed ok but I dont think the cooling fans are kicking in. I checked the fuses and they also seem ok as well as the connections. Can anyone help me please? Its only happening when the cars stationery for a period of time.
reganlives
05-05-2019, 10:32 AM #1
05-05-2019, 10:46 AM
Water pump not operating effectively?
Is the interior heater working as it should?
05-05-2019, 10:46 AM #2
05-05-2019, 11:17 AM
Check the fan relays. If they are faulty I have a spare set for sale. Smile
05-05-2019, 11:17 AM #3
reganlives
05-05-2019, 11:48 AM
I think the water pump is ok. The heating is fine. Wheres the fan relays stay and how do I check them?
reganlives
05-05-2019, 11:48 AM #4
05-05-2019, 12:47 PM
In the fuse box in the engine bay, take it out and put 12v across it to check it clicks.
05-05-2019, 12:47 PM #5
reganlives
05-05-2019, 01:05 PM
ok mate. I'll try that. How much do the relays normally cost?
reganlives
05-05-2019, 01:05 PM #6
05-05-2019, 01:06 PM
Not cheap from Lexus, but I may have some of them as well lol
05-05-2019, 01:06 PM #7
mattlaw
05-05-2019, 03:55 PM
Check the temp sensor at the bottom of the rad on the left hand side, the sensors go faulty and the wires corrode, seen it a few times
mattlaw
05-05-2019, 03:55 PM #8
reganlives
07-05-2019, 03:41 AM
Right guys, I've found the culprit! Matt, you were right! Its the wires on the temp sensor and one of the wires has corroded and basically broken so I really need to fix this now but I dont know how. Does anyone have any tips? All I can think of at the moment is as the wire is so long from the loom then get a one from a scrappy and basically cut it and splice it together with another one....
Anyone got any bits laying about? Wink
Cheers
reganlives
07-05-2019, 03:41 AM #9
Cheers
reganlives
07-05-2019, 03:46 AM
heres a pic:
[Image: 17062012155.jpg]
reganlives
07-05-2019, 03:46 AM #10
heres a pic:
