JapCarForum Cars, Cars, Cars! General Car Maintenance Two stage boost removal just done it :-)
Pages (3): 1 2 3 Next
13-07-2016, 09:53 AM
Been meaning to do this for a while now so thought i'd sort it out at last, Its a very simple mod and another freebie but does seem to make a difference to the car and how it goes? :tongue_smilie:
My Skyline has the two stage boost system (think most RB25 skylines have?) and it usually runs around 0.5bar up to 4500-5000rpm then goes up to 0.7/0.8bar upto 7000+rpm,
This little mod removes the 2 stage boost part and gives you the higher 0.7/0.8bar of boost all the time so more power all the way through the rev range :thumbup1:
it ups the pressure from about 7.25psi to 11.6psi approx, so about 4.35psi more pressure?
Very simple to do as it only takes 1 wire from the boost solenoid which you ground out to the body of the car, I've just done it and have only earthed it out but on Wednesday i'll be fitting a switch in the dash, so that i have the choice of running 2 stage boost for normal driving or single stage for a bit more fun. (always be on single knowing me:laughSmile :thumbup:
Connector block on the solenoid earth wire..blue earth wire can just be seen under the solenoid?
(will be nice and tidy when i redo it?)
[Image: boostmod1.jpg]
Earthed out on the body..
[Image: boostmod2.jpg]
And how i'll be wiring the switch in on Wednesday..to give you an idea of how simple this mod is?
[Image: boostmodswitchwiring.jpg]
Hopefully fit it here like this chap has?
[Image: boostswitchfitting.jpg]
Will try and do a "how to" when i re-wire it and add the switch and take a few more pic's?
Simple and free to do if you have a bit of wire and a switch, giving you better boost all through the rev range and a choice between 2 stage and single stage :thumbup1:
Edited 25-08-2009, 12:12 AM by Bandit.
13-07-2016, 09:53 AM #1
13-07-2016, 09:55 AM
Another good reason to buy a Skyline, seeing how easy it is to ramp up the power ! Good work and thanks for sharing :biggrin:
13-07-2016, 09:55 AM #2
13-07-2016, 09:59 AM
Thanks matey :thumbup1:
The main reason i've done it is because my solenoid seems to make it up as it goes along, I could really do with a new one because it usually sticks at the 0.5 bar setting all the way through the rev range, so to have 0.7/0.8 bar should be a lot more fun :w00t:
13-07-2016, 09:59 AM #3
russelllinn
13-07-2016, 10:22 AM
Sounds good and looks so simple too :thumbup1: Gotta be a must have performance mod for the RB25 users eh.
How have you found the 0.7/.08bar boost all through the range?
russelllinn
13-07-2016, 10:22 AM #4
13-07-2016, 11:05 AM
Just been for a blast and got to say it works to great effect :w00t: the pick up all the way through is fantastic, enough to make your legs shake with excitement :laugh:
On the private road i've just been down Wink i can usually hit around 125mph in 4th before i have to brake, i've just hit 140+ in the same space (had to use 5th gear) so i'm well impressed and it now feels like a skyline :thumbup1:
For a comparison its like when you 1st fit a supercharger to an IS200, It picks up great and puts a huge smile on your face Big Grin
13-07-2016, 11:05 AM #5
13-07-2016, 11:07 AM
Sounds great ! :w00t:
13-07-2016, 11:07 AM #6
13-07-2016, 11:08 AM
Feels great :laugh: For a free mod its worth every penny Big Grin
13-07-2016, 11:08 AM #7
aaronabbott
13-07-2016, 11:10 AM
such a simple job:wink:
how will it effect the life of the turbo
aaronabbott
13-07-2016, 11:10 AM #8
13-07-2016, 11:15 AM
The turbo should be fine mate, they say dont take it above 0.85-0.9bar on the standard turbo? some guys run theres at 1bar and still havn't had any problems so running 0.7-0.8bar should be fine :thumbup1:
If the turbo does go, you can see them quite often on ebay or on the owners clubs for less than £100, so its not too bad unless i want to upgrade and go bigger, then it costs quite a bit more? Big Grin
13-07-2016, 11:15 AM #9
13-07-2016, 11:21 AM
Might have to do a test flight with a couple of you guys while were at JAE to see what you think of it?
I've not taken anybody for a spin yet and be good to have another point of view on how it goes Cool
13-07-2016, 11:21 AM #10
Views 867
13-10-2022, 03:40 PM
Last Post by Superman
Views 876
19-07-2019, 05:18 AM
Views 928
17-07-2018, 05:03 PM
Last Post by D.F!ANT
Views 1,544
02-06-2018, 01:28 AM
Last Post by RichyUK
