JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Workshop - Submit Your Tip! De-cat EML fix p0420,etc fix
164
12-05-2019, 11:40 AM
Hi
though i would just let everyone know as i know some others have this problem.
So if any one has fitted a de-catted manifold or main decat, if you have been getting the p0420 error code and have tried adapters, simulators etc and still getting EML then this fix could help.
So after hours/days of research i found a cheap fix for getting rid of the EML code you get from de-catting.
Anyway all the fix is to wire a 1.2k ohm resistor in series on the signal wire (the one that send a voltage to the Ecu) on the post cat sensor the(main cat O2 sensor), on the Denso sensors it is the blue wire, on others with other colours its usually black wire, but check.
Anyway all you need to do is cut and solder the resistor on the signal wire and wipe the error code and its fixed! 26p well spent.
All it does is sends a lower signal to ecu, which is what it would do if there was a Cat there. if it sends to low or high as signal try a bigger or smaller rated resistor.
I found this on various Nissan, and Subaru forums, So i
am not taking credit just passing on the knowledge.
hope this helps others out as i had been trying to sort mine for weeks!
lookatmybiceps
12-05-2019, 11:40 AM #1
Hi
12-05-2019, 11:44 AM
Worthy of a rep button press I think!!
12-05-2019, 11:44 AM #2
Jon
15-05-2019, 10:01 AM
Can you let us know, if - after afew days of driving - this works? If so, i'm tempted to do it myself
Jon
15-05-2019, 10:01 AM #3
164
16-05-2019, 06:52 AM
yeah defo works had it fixed for about a week now, where the light used to come on every 10miles ive done now about 200 so working fine.
lookatmybiceps
16-05-2019, 06:52 AM #4
Jon
16-05-2019, 01:06 PM
Think i'll do this, can it be done anywhere - ie near the ecu instead?
Mine normally comes on after 60 or so miles, or afew miles of hard driving.
Jon
16-05-2019, 01:06 PM #5
