JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza 1g-gte piston with 1g-fe rod?
gc8_g_r
18-06-2020, 12:23 AM
HI, I am wondering if the 1g-gte piston can fit with 1G-FE rod..
The pin is the same or not?
cheers
leo
gc8_g_r
18-06-2020, 12:23 AM #1
cheers
leo
LEX11S
25-06-2020, 08:13 AM
why would you want to use the std rod?
LEX11S
25-06-2020, 08:13 AM #2
gc8_g_r
25-06-2020, 11:15 AM
LEX11S why would you want to use the std rod?
cos' I am using the stand 1G-fe rod as a sample to custom make a forged rod..the lentgth/pin hold and other specs are all same except the forged one is beam..
so I am wondering if standard 1g-fe rod can fit a 1G-gte piston.
hope someone can help
gc8_g_r
25-06-2020, 11:15 AM #3
LEX11S
09-07-2020, 11:33 PM
As fair as i know they do i got told that i could use the 1ggte rods with the 1gfe piston
i just used the 1ggte rod and piston in the end
LEX11S
09-07-2020, 11:33 PM #4
gc8_g_r
09-07-2020, 11:55 PM
LEX11S As fair as i know they do i got told that i could use the 1ggte rods with the 1gfe piston
Thanks mate,now I know what I can do..I can keep custom make forged rod which absolutly copy stock 1g-f rod data but just I beam...then sell my 1g-gte stock rod. Thanks again,mate.
cheers
gc8_g_r
09-07-2020, 11:55 PM #5
cheers
Views 414
08-07-2020, 07:32 AM
Views 612
19-06-2020, 06:51 AM
Last Post by sprinter2012
Views 556
12-06-2020, 11:38 PM
Last Post by gc8_g_r
