JapCarForum Cars, Cars, Cars! Help Topics - Submit Your Help For Other Members! Oil cooler fitment
Oil cooler fitment
Oil cooler fitment
goonerden
24-06-2019, 08:34 AM
I would like to fit an oil cooler to my Lexus IS200 (2003). Does anyone have any advice/experience with fitting one? Any help much appreciated!:confused1:
goonerden
24-06-2019, 08:34 AM #1
24-06-2019, 09:41 AM
I have one on mine. Although its a different engine.
You'll struggle on the standard engine as there is sweet fa room by the filter. But any will fit if you get the right thread adaptor.
24-06-2019, 09:41 AM #2
goonerden
25-06-2019, 06:16 AM
Thanks for the reply. Any tips for finding the right thread adapter? Also, am I right in thinking I'll need to fit a smaller oil filter?
goonerden
25-06-2019, 06:16 AM #3
25-06-2019, 06:20 AM
Out of interest why do you need one?
The OEM set up is just fine unless your going to introduce forced induction or long distance towing.
25-06-2019, 06:20 AM #4
goonerden
25-06-2019, 06:31 AM
none been told it will help engine oil psi
goonerden
25-06-2019, 06:31 AM #5
25-06-2019, 06:53 AM
I believe the thread is 3/4 UNF if that helps but you don't need an oil cooler. As mentioned you've not got much space to get a sandwich plate in, and then you'll be running 2 oil coolers as the stock water jacket will still be there...
25-06-2019, 06:53 AM #6
25-06-2019, 07:04 AM
goonerden none been told it will help engine oil psi
whats wrong with your psi?
Have you changed oil grade?
if its too low i'd look at the pump, or a leak.
a way of upping the pressure is to put a small washer on the pump relief valve screw. but like its been said the standard engine is fine without one, so if youve a high or low pressure you need to find the problem.
25-06-2019, 07:04 AM #7
25-06-2019, 09:44 AM
i fitted one to mine. yes there is room for it.
25-06-2019, 09:44 AM #8
25-06-2019, 09:46 AM
[Image: IMG_0096.jpg]
[Image: 5bd99bd4.jpg]
25-06-2019, 09:46 AM #9
Views 939
29-08-2020, 09:14 PM
