JapCarForum Trade Area Trade Archive Selling Archive Mr2 rev 3 N/A engine, gearbox etc, low miles, 100s spent
Fozzy
05-07-2019, 12:22 PM
Im removing this engine due to a turbo conversion, despite I only fitted it 12 months ago. I bought the engine from imoc. Original sale thread here
http://www.imoc.co.uk/forums/viewtopic.p...t=#1261888
The engine came with the cambelt removed, and the waterpump missing. I replaced the waterpump with a unit from camskill, the thermostat and housing was also replaced, a new cambelt was also fitted. The engine was then given a service using genuine items from mr t, including proper rev 3 plugs (£9 each!), and new dizzy cap and rotor arm, new engine temp sensor.
When fitted I first filled it with crappy oil, ran it for a couple of hours, then drained and refilled with magnatex and a new filter to make sure there was no rubbish in the engine. While it was out I cleaned and painted the rocker cover, inlet manifold and heat shield. The gearbox was also cleaned and repainted.
I also replaced the lambda sensor in the downpipe, and replaced the coil pack and igniter, as it was split. While it was apart a new clutch was also fitted.
Since fitting I don't think I have run more than about 5-6000 miles, so being generous I'd say it's done 60,000 miles in its life. The engine starts first time every time, and pulls really well, it's such a shame to remove it really, but more power is a must.
This will come with most parts of the rear clip, engine gearbox, downpipe, no back box, ecu, loom, driveshafts, hubs etc. The hubs are from a uk abs car, so come complete with sensors.
The engine is currently still in the car if anyone wanted to see it running or drive it. It will be removed hopefully in the next few weeks
£300 collected
[Image: 8acf98e7dd629bcba8478a9ec2b38240.jpg]
[Image: DSC00613.jpg]
Does not include the BMC filter or TRD leads. It will come with a set of standard leads, but no filter, as I don't have a spare
Edited 15-08-2012, 09:57 PM by Fozzy.
2009 JAE Car Pull Runner Up
2010 JAE Car Pull Failure
Fozzy
05-07-2019, 12:22 PM #1
£300 collected
speedfreek
05-07-2019, 12:43 PM
This engine pulls HARD - so it's definately all hot to trot.
Good luck with sale Pete.
'99 Lexus IS200 SE Navigator
[/SIZE]
(Current project)
speedfreek
05-07-2019, 12:43 PM #2
[/SIZE]
(Current project)
Views 811
28-04-2020, 04:35 AM
Last Post by Chris0121
Views 139
01-01-2020, 02:23 AM
Last Post by ramplin
Views 350
18-10-2019, 11:33 AM
Last Post by john wan
Views 467
28-02-2019, 03:29 AM
Views 438
26-04-2018, 12:18 PM
Last Post by jimxms
Views 1,291
09-02-2018, 03:13 PM
Replies 27
Views 1,705
31-10-2016, 01:49 AM
Last Post by ormi
Views 490
16-10-2016, 12:08 PM
