JapCarForum Car Manufacturers Nissan Modifications & Tuning Hicas??
Hicas??
Hicas??
Hami
12-07-2019, 09:58 PM
While I was changing over the Dash bulbs etc i noticed that my HICAS bulb was missing/taken out, so I replaced it to only find out that it stays on non stop, I am taken this as bad news, but was wondering if that could be my trouble of pulling to the left?
Hami
12-07-2019, 09:58 PM #1
Multics
12-07-2019, 11:30 PM
If your Hicas system has been removed then it's normal that the bulb is lit. Most people remove the bulb when they remove the rear wheel steering system. Check under your car if Hicas is still there or if there's a solid bar.
Lexus IS 250 SE-L
Multics
12-07-2019, 11:30 PM #2
Lexus IS 250 SE-L
Hami
12-07-2019, 11:59 PM
Nope i have the HICAS still on my car
Hami
12-07-2019, 11:59 PM #3
speedfreek
13-07-2019, 01:00 AM
Possible that there is a problem with it then, as on the R33 it's an electronic system.
That would be why the bulb may have been removed as it's cheaper than sorting it out.
I would just stick a lockout bar in and unplug the hicas computer (in the boot I think) and get the bulb removed again. Hicas is pointless really anyway.
'99 Lexus IS200 SE Navigator
[/SIZE]
(Current project)
speedfreek
13-07-2019, 01:00 AM #4
[/SIZE]
(Current project)
Hami
13-07-2019, 01:59 AM
Cheers once again guys :-)
Would that cause my car to pull left do you recon!?
Hami
13-07-2019, 01:59 AM #5
jj260z
13-07-2019, 04:28 AM
speedfreek Possible that there is a problem with it then, as on the R33 it's an electronic system.
pointless if it dont work as it was intended very clever and good when it is working
jj260z
13-07-2019, 04:28 AM #6
speedfreek
13-07-2019, 06:20 AM
jj260z pointless if it dont work as it was intended very clever and good when it is working
No, it's pointless in all instances.
Rear steering assist doesn't add anything significant to the party at all.
Believe me, having had 5 skylines - I'm qualified to state that Big Grin
[/SIZE]
(Current project)
speedfreek
13-07-2019, 06:20 AM #7
[/SIZE]
(Current project)
Multics
13-07-2019, 06:49 AM
Same here. Ditch it.
Lexus IS 250 SE-L
Multics
13-07-2019, 06:49 AM #8
Lexus IS 250 SE-L
Hami
13-07-2019, 07:29 AM
Okay it's getting ditched as soon as I can order up a lock out bar, on that note where is best place to source one??
Looked at Japspeed n drift works, any where else or just go with one of them?
Hami
13-07-2019, 07:29 AM #9
speedfreek
13-07-2019, 08:48 AM
From memory, either will be OK - they both do the job Smile
[/SIZE]
(Current project)
speedfreek
13-07-2019, 08:48 AM #10
[/SIZE]
(Current project)
