JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications Problems with MAP sensor ?
farnsworth67
29-07-2019, 08:31 AM
Hi All
I know there has been a lot of talk about MAP sensors and TTE superchargers, and to be honest i have read a lot of it!
I had the usual cutting out problems and the diagnostics telling me that there is a MAP problem.
I have replaced the original black box with a HKS FCD, standard part, and i have set the dial to 9.
Unfortunately this hasn't cured my problem :confused:
I now get cut off happening with i get above 3000 revs, but it recovers as soon as i get off the throttle. The other thing i see is that the reported MAP level from OBD2 is constantly high and doesn't move as i drive. Do i have a dodgy MAP sensor as well?
Any help would be appreciated
farnsworth67
29-07-2019, 08:31 AM #1
Hi All
29-07-2019, 08:59 AM
Hmm sounds like a faulty map sensor to me. I may have one at home you can try if you want?
Pm me and I'll dig it out when I'm back from jae.
29-07-2019, 08:59 AM #2
farnsworth67
02-08-2019, 04:50 AM
Hi
Just some further updates, i have replaced the MAP sensor, but the problem is still the same.
I have now checked the voltages going into the FCD and coming out of the FCD, when the car is idling
Voltage in 1.6V
Voltage out 5.66V
So to me this suggest that the MAP sensor is ok, but the FCD is doing something strange. From what i understand the FCD limits the signal from the MAP sensor it shouldn't boost it.
If i just bypass the FCD what will happen?
Help!!!
farnsworth67
02-08-2019, 04:50 AM #3
Hi
Voltage in 1.6V
Voltage out 5.66V
Help!!!
P.Lindblom
02-08-2019, 07:25 AM
farnsworth67 Hi
Voltage in 1.6V
Voltage out 5.66V
Help!!!
If you remove or bypass the FCD everything should be fine below 6000rpm. Full throttle plus high revs will make you hit fuel cut.
P.Lindblom
02-08-2019, 07:25 AM #4
farnsworth67 Hi
Voltage in 1.6V
Voltage out 5.66V
Help!!!
farnsworth67
02-08-2019, 07:38 AM
Thanks for the quick response i will bypass and give it a try
farnsworth67
02-08-2019, 07:38 AM #5
Views 241
29-11-2022, 03:38 AM
Last Post by phaebo
Views 238
14-02-2020, 10:45 AM
Last Post by argyle dan
Views 610
25-11-2019, 12:18 PM
Views 436
24-02-2019, 05:29 AM
Last Post by lookatmybiceps
Views 699
18-12-2017, 12:24 AM
Views 498
29-09-2017, 08:06 AM
Views 743
05-07-2017, 12:46 PM
