JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Modifications & Tuning LED brake/tail & indicator bulbs
Pages (3): 1 2 3 Next
jomo
13-08-2020, 04:04 PM
Was thinking of swapping over to all led bulbs, anyone done this yet on their is200?
Do i need red or white for the stop/tail as the lens is red all ready?
I know they do white looking leds that flash yellow for the signal/turn.
Are these any good or stick to ye olde type?
jomo
13-08-2020, 04:04 PM #1
13-08-2020, 04:10 PM
I've done it all on mine mate, stick with getting the right colours, ie red for brakes, amber for indicators etc
13-08-2020, 04:10 PM #2
jomo
13-08-2020, 04:14 PM
Cheers Marc, any chance you have pics of the ones you bought or like to fleabay ones?
jomo
13-08-2020, 04:14 PM #3
jomo
*Links*
jomo
13-08-2020, 04:14 PM #4
*Links*
13-08-2020, 04:27 PM
No sorry mate it was a while ago. Recommend the tower LEDs though.
13-08-2020, 04:27 PM #5
14-08-2020, 11:34 AM
If you do it make maybe get some pics up would like to see what they look like
14-08-2020, 11:34 AM #6
jomo
16-08-2020, 02:17 PM
Will do, got some on order, so as soon as their in my mitt ill do a few pics maybe a video walk through to!
jomo
16-08-2020, 02:17 PM #7
jj260z
17-08-2020, 07:14 PM
I always found the LEDs were never bright enough even if you buy the super bright ones compared to a normal bulb.
You couldnt see the brake lights during the day.
jj260z
17-08-2020, 07:14 PM #8
jomo
20-08-2020, 08:53 PM
Ok guys small update, received a few led bulbs today and after fitting them in the indicators i found that they flashed too quick as if there was a bulb out!
Spoke to guru Stav who said i needed a led relay to prevent this, looked high and low across the net tonight but cant find one? And the ones on ebay only do the newer Lexus's.
Plus Stav also said that the brake warning light comes on when fitting stop/tail leds and the way round was to fit load resistors or remove the warning light bulb from the speedo cluster!
So its turning into a real cluster fu ck!
If anyone has any more suggestions i'm all ears, but for now its taking a back seat!
jomo
20-08-2020, 08:53 PM #9
21-08-2020, 05:25 AM
Try eBay item: 200825264330
As for the dash light. You can remove the bulb, fit the load resister (but the light out wont work anyway), or if you get the light failure unit in the boot you can remove two wires from that.
21-08-2020, 05:25 AM #10
Views 2,016
14-02-2019, 05:55 PM
Views 1,022
19-12-2018, 04:08 PM
Views 2,187
06-10-2018, 02:49 PM
Last Post by LEX11S
Views 1,653
19-04-2018, 07:45 PM
Replies 22
Views 2,560
25-01-2018, 04:58 AM
Replies 24
Views 2,523
16-01-2018, 08:50 PM
Last Post by Chri5
Views 1,555
31-12-2017, 04:23 AM
Last Post by phil
