JapCarForum Cars, Cars, Cars! General Car Maintenance 100k service
100k service
100k service
Ji123
23-08-2019, 03:39 PM
my car is approaching the 100k mark and i would like to know the grocery list of all whats needs to be changed / replaced
al i know so far is that i have to change timing belt and spark plugs.
also what gaskets or seals can i change
nb. i am getting some oil when i remove spark plugs
Ji123
23-08-2019, 03:39 PM #1
24-08-2019, 12:29 AM
Does this not kind of depend a little bit on what kind of car it is, what the dealer handbook says is due and most importantly what you have or haven't already replaced at it's previous services ? Smile
24-08-2019, 12:29 AM #2
Ji123
24-08-2019, 02:09 AM
getting a bit of oil by the spark plugs what gaske or seal do i need to change? and what about timing belt tensioner?
Ji123
24-08-2019, 02:09 AM #3
24-08-2019, 02:31 AM
If your timing belt hasn't been done then expect to do that job, may as well do water pump, and tensioner at the same time.
Oil on the plugs could be coming from several places?
24-08-2019, 02:31 AM #4
24-08-2019, 02:38 AM
Depends on the car really, as PW said!
24-08-2019, 02:38 AM #5
Ji123
24-08-2019, 12:34 PM
is the tappet pan gasket and the valve cover gasket the same or differeent .. someone advised me i need seals for the spark plugs..
Ji123
24-08-2019, 12:34 PM #6
24-08-2019, 02:15 PM
As seems to have been asked a few times, what car is it? :biggrin:
24-08-2019, 02:15 PM #7
Ji123
24-08-2019, 03:22 PM
sorry toyota altezza as200
Ji123
24-08-2019, 03:22 PM #8
24-08-2019, 09:59 PM
Ji123 sorry toyota altezza as200
The AS200 is the same as the IS200 isn't it technically? Isn't therefore the cambelt supposed to be done at 60k?
24-08-2019, 09:59 PM #9
Views 374
22-11-2019, 08:45 AM
Views 545
15-03-2019, 11:57 PM
Last Post by Mikey
Views 609
21-09-2018, 06:48 AM
Last Post by Stoney
Views 320
10-08-2018, 11:03 PM
Last Post by Mrs HollowPoint
Views 1,273
09-12-2017, 10:57 AM
Views 443
28-05-2016, 01:52 AM
Last Post by Bobby
