JapCarForum Car Manufacturers Lexus/Toyota bc coilovers
bc coilovers
bc coilovers
old school
27-08-2019, 02:21 AM
HELP.......
just had bc coilovers fitted to my mk2 aristo,allso fitted new front lower ball joint as it was all apart.
they are a great inprovement on the car but i have picked up a wine on the left hand side front when i turn right hand down ?its fine on left hand down ???
its got me stumped ?
old school
27-08-2019, 02:21 AM #1
HELP.......
27-08-2019, 04:10 AM
wheel bearing, possibly.
27-08-2019, 04:10 AM #2
old school
27-08-2019, 07:36 AM
did think of this,but does not nock ,its more of a wine.
old school
27-08-2019, 07:36 AM #3
27-08-2019, 12:40 PM
that's exactly what I had, it was a wheel bearing. I think everything else starts letting go when you upgrade stuff. If it is a whine on the left side when you turn right, that sounds absolutely identical to my wheel bearing problem, which surfaced shortly after adding coilovers and replacing a few other weak points. I think the wheel bearings start whining because they are the next weakest part.
Check for play in the wheel, but it sounds absolutely identical to the symptoms I had, which turned out to be a wheel bearing.
27-08-2019, 12:40 PM #4
Views 308
24-12-2022, 09:31 AM
Last Post by rock on
Views 235
31-12-2019, 04:01 AM
Last Post by old school
Views 2,581
12-07-2018, 01:15 AM
