JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Engine & Transmission p0785 code :(
p0785 code :(
p0785 code :(
06-09-2019, 09:20 AM
got a p0785 code on the way home, Shift/Timing Solenoid. anyone have any knowledge on how to fix? tried searching not found anything of help yet. :cursing:Confusedad:
06-09-2019, 09:20 AM #1
Phil01
06-09-2019, 09:26 AM
How does the car drive like Dean? is the gear changes good or does some gears appear to slip
Phil01
06-09-2019, 09:26 AM #2
paddywak
06-09-2019, 09:28 AM
is300_dino got a p0785 code on the way home, Shift/Timing Solenoid. anyone have any knowledge on how to fix? tried searching not found anything of help yet. :cursing:Confusedad:
Dino there could be a few reasons but all relate autobox
Low g/box oil. Dirty box oil. Faulty solonoid valve. Or dirty loose connection
Hope that helps
Paddy
paddywak
06-09-2019, 09:28 AM #3
Hope that helps
Paddy
Phil01
06-09-2019, 09:29 AM
Im guessing a shift valve solenoid as it indicates an open circuit
Phil01
06-09-2019, 09:29 AM #4
06-09-2019, 09:38 AM
this morning on the way to work felt a bit jumpy, and seemed ok on way home got about half way back and light came on reset whilst driving on the scan gauge and came back on almost instantly.
the oil is less than 500miles old (3 weeks) from the rebuild still running engine in, had a GB oil cooler fitted to. so possible leak or soleniods crapped.
06-09-2019, 09:38 AM #5
06-09-2019, 09:39 AM
anyone know where to get a replacement noid or price?
06-09-2019, 09:39 AM #6
Phil01
06-09-2019, 09:40 AM
Let me do some research on this code tonight dean
Phil01
06-09-2019, 09:40 AM #7
Phil01
06-09-2019, 09:41 AM
if it is the solenoid it will be internal attached to the valve body.
might just be a connector or wire as generally the solenoids are robust
Phil01
06-09-2019, 09:41 AM #8
06-09-2019, 09:54 AM
suppose twould be a good time for the valve upgrade kit too, neeed more money Sad
06-09-2019, 09:54 AM #9
mattlaw
06-09-2019, 11:17 AM
Have you checked the ATF fluid level? Start with the basics
mattlaw
06-09-2019, 11:17 AM #10
Views 132
19-06-2021, 12:09 AM
Last Post by marko45
